| OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Removing wheel stud
Okay, so last night I broke a wheel stud. Does anyone have any good suggestions for removing the broken one without buying the stud removal tool from Chrysler?
#2
a BFH
#3
Hammer, drift punch worked for me. You may want to pull the assembaly 1st and support the flange around the stud. I did it on the XJ, but it may be hard on the bearing.
Rev
The MWC's Rev. Dr. MWC Motto - We eat our own, but God help any outsider who tries to take a bite. MWC Members - Check out http://www.midwestxj.org God watch over Travis |
#4
No BFJ
BFH is a bad idea because of the c-clip axle. Hammering on it can damage the c-clip causing all kinds of very expensive problems later on.
Of course, if I take the entire hub assembly off the Jeep, then pounding on it isn't a problem, but I was hoping to not have to do that. |
#5
Re: No BFJ
You can always drill it out. Drill enough of the stud so that there is only a thin wall left between it and the hub flange, then a light tap with a hammer and drift will knock that sucker right out.
XJguy |
#7
i broke one last week and did'nt replace it yet but i took the broken one out, i did'nt even need a hammer, 1 hit with a 1/2" drive ratchet popped it right out like it was nothing. Reason i did'nt replace it yet is because they way i went about doing it is putting the new stud in, then putting some washers on it and a big nut to pull the stud through and into place but i can't get enough damn torque on the nut to pull the stud through even with a 1/2" breaker bar, guess i need air tools.
Eric |
#8
i spun a stud in the hub last month and it would not reset for nothing... the replacement from napa didnt fit tight i guess the hole was damamged.. i had to throw a tack weld on the back to hold it in place
mike
mike (moab-on-the-brain) ZJ grocery-getter 83 CJ-5 mall wheeler |
#9
Re: Removing wheel stud
I've done u-joints and I can't remember, do you have to pull the axle shaft to replace the wheel stud on the front, or can you slide 1 stud out without doing this?
#10
I removed ALL my studs on all my hubs. I thought it was going to be a nightmare.
I doused them all with PB, next morning I just had to give them a few taps with a L(as in little)FH. Just a regular hammer with less force than pounding in a 16 penny nail. After two or three taps they gave way. It took me about 5 minutes to remove 20 studs. My alternative (plan B) was to use a big socket and a C-clamp and press it out, but I never had to go that route. Plan C was heat and tap, Plan D was to rent an appropriate tool like a ball joint press.
I don't know if I know anything at all, but I sure know I don't know everything. 1990 XJ, 4.0, AW4, Open Cooling, 3.5" full pack. Bunch of other mods. 1988 MJ, 4.0, 5 speed, open cooled, work in progress. The MJ project: http://www.comancheclub.com/forums/v...hp?f=7&t=22382
#11
Front or rear?
C-Clamp and a big socket |
#13
Press or hammer the replacement in. You usually cannot generate enough force with the threads, it will not seat fully or shear the replacement stud.
I suck at life |
#14
No. But on the fronts, the dust shield for the brakes was kind of problematic. I cut a small notch (1/2" x 1/2") in the shield to allow the studs to come out as I rotated the position relative to the notch. The rears...no sweat. I have a D44 on the MJ if that makes a difference
I put in studs that were 1" longer, I used an old wheel spacer and the open ended nuts that came with the spacer. I greased the stud ferrule (?) and cranked on the stud with a breaker bar. The studs pulled right in, and seated into the recessed part of the hub flange. I did have to do a little searching for the right studs, and they were $2.25 a piece. $45 for all new studs.
#15
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4 wheel drive release question?? | Lewis | OEM Tech Discussion | 12 | 05-14-2006 08:27 |
| Wheel U-Joint | ken johnson | OEM Tech Discussion | 5 | 12-06-2003 21:17 |
| Strange wheel vibration | SV1CEC | Modified Tech Discussion | 23 | 09-16-2003 09:12 |
| Wheel Stud Replacement | Bill-93XJ | OEM Tech Discussion | 6 | 08-20-2003 09:27 |
| Wheel weights and balancing tires-help! | Uni | Modified Tech Discussion | 6 | 06-11-2003 14:16 |
