Old April 2nd, 2005, 16:28
MoFo MoFo is offline
Gone but not forgotten...
Driveshaft lengths?
I am in the process of taking my '87 Cherokee up 5 inches. It has the Dana 44 and I keep reading questions about how much longer a shaft is needed for a certain lift. I also understand the D35 shaft is longer, and the Corporate axle equipped shafts are in between. I have another '87 XJ with the D35, so I will be able to try that. But I was wondering...
Does a list exist of the driveshaft lenghts for various XJ vehicles, with the D35, D44 and Corp. axles. Are the Manual vs AW4s different lengths? If no list exists, should we start a thread with actual measurements?
Thanks for your time.
MoFo
Old April 2nd, 2005, 21:07
Bmxpunk1369's Avatar
Bmxpunk1369 Bmxpunk1369 is offline
Re: Driveshaft lengths?
manuals for the front are ~2 inches shorter than an auto for the front. My auto front shaft measured 28-31. My friends manual was 27-30. I know the rears of some will be different but i dont know if you would want to run a stock slip yoke shaft with 5 inches of lift. Just go to the junkyard and do some measurements. Im sure you could find one to work.
Old April 2nd, 2005, 21:21
Thanks, I know the junkyard routine. I just thought that it would be nice to not do the junkyard thing after the last 20 people did it, and possibly save the next 20 people the same work.
XJ Front Driveshaft Lengths... kee Modified Tech Discussion 1 February 26th, 2005 11:59
Stickshift front Driveshaft Lengths? 79yj OEM Tech Discussion 8 September 15th, 2004 12:40
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
Driveshaft lengths dgmachinist OEM Tech Discussion 8 July 31st, 2003 20:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
