Old April 1st, 2005, 15:32
XJMJguy's Avatar
XJMJguy XJMJguy is offline
AX5 swap for AX15???
okay, I have an 87' comanche 4.0 with an AX5 tranny and an np231 transfer case. I am getting a new np231 from a friend for $100 and he says he'll give me the tranny for $200 more which I believe is an AX15. my question is: how much better of a transmission is the AX15 over the AX5? my AX5 seems to be in good shape other then the slave cylinder (the reason it is out), so would it be worth it to try and do a tranny swap assuming it is an AX15 with a 21 spline output shaft? thanks in advance
Old April 1st, 2005, 16:37
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: AX5 swap for AX15???
Are you certain that you have an AX-5? An '87 MJ with 4.0L should have a Peugeot BA 10/5 transmission. The AX-5 was used behind the 4-cylinder engines.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old April 1st, 2005, 17:09
XJMJguy's Avatar
well the tranny is dated 90' so it isnt the original, I am pretty sure it is the AX5 though, I will double check as soon as I find my 4wheel magazine with all the tranny pics in it. but is the AX15 better then the AX5???
Old April 1st, 2005, 17:40
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: AX5 swap for AX15???
running a 4.0L with a tranny designed for a 4cyl motor is asking for problems...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old April 1st, 2005, 17:55
XJMJguy's Avatar
okay, I am wrong. upon closer inspection Eagle was right it is the Peugeot BA 10/5, so now it seems the question would be: is the AX15 a better tranny then the Peugeot BA 10/5? and if it would be worth it to swap?
Old April 1st, 2005, 18:19
XJMJguy's Avatar
well now I have answered my own question with my new found knowledge. through a search it seems many feel the Peugeot BA 10/5 is a horrible tranny so it seems it would be a good idea to upgrade. thanks guys for the info.
Old April 1st, 2005, 18:53
over2land's Avatar
over2land over2land is offline
NAXJA Member #1171
The AX-5 is difficult to swap out for an AX-15.
However... since that isnt' what you have...
The Peugot junk, the AX-15, NV3550, and the 6 spd all will bolt up to the 4.0.
I know the AX-15 and the 3550 interchange with no dshaft mods.
The peugot and the AX-15, dunno.
Also, try to go with the external slave at the same time if you at all can. Those internal slaves suck.
Old April 1st, 2005, 19:19
old_man's Avatar
old_man old_man is offline
The AX-15 is a definate upgrade. Be careful on what tranny fluid you run. There are problems with some of the fluids eating the syncros. If you can, make sure and get a tcase shifter for the AX-15/NP231. I'm pretty sure they are different, but easily found at most junk yards. I may be wrong but there may be a slight difference in the driveshaft lengths.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old April 2nd, 2005, 16:25
XJMJguy's Avatar
cool, thanks for the input unfortunately my friend has the same "Peugot junk" I do so, it looks like for now I'll just stick with it. I am interested in this 6 speed over2land speaks of. Is it the new 6 speed they are putting in the wranglers or was it used in some other application?
Swap 4.0 for 4.0HO DADDJP Modified Tech Discussion 2 August 18th, 2005 18:46
Help with axle swap semisynth OEM Tech Discussion 2 November 17th, 2004 13:59
4 litre H.O swap vs. v8 swap... atowley Modified Tech Discussion 7 May 19th, 2004 12:40
Finished D60/D70 axle swap XJoachim Modified Tech Discussion 40 December 9th, 2003 20:35
2.5L to 2.8L swap? bigoltrux77 Modified Tech Discussion 11 September 8th, 2003 18:17
