Old March 25th, 2005, 09:15
Rocketman's Avatar
Rocketman Rocketman is offline
Most Important
OK... $$$$ as with anyone is tight. I have enough BLING on my Jeep (too much actually) and need to add something more critical since it iis my DD and carries my two little ones around. Considering most wheeling is on the Midwest trails, which is MORE important, under body skids, (engine, TC) OR Rock rails? Which would get more abuse? I'd think and Engine/tranny armor? BOTH will wind up on the XJ eventually BUT, FIRST??? LCA skids perhaps to the list?
Arguments, opinions, recommendations... all are welcome.
Thanks,
Old March 25th, 2005, 09:27
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
Re: Most Important
Based on your type of wheeling, If it's a question or either/or, I'd vote for T-Case skid first. Doesn't take much to punch a hole in the aluminum Case. Rock rails are the other part on the either/or list. If you can swing it, get these also, or at least the very next thing. Gas tank skid after that. Skip the LCA skids and put the rock rails higher on the list.
My $.02
Old March 25th, 2005, 09:28
Citat3962's Avatar
Citat3962 Citat3962 is offline
Re: Most Important
Where can you even get LCA skids?
Old March 25th, 2005, 09:41
wescam's Avatar
wescam wescam is offline
Re: Most Important
Skid Row makes some nice LCA skids, and I plan to get them unless a local guy I'm talking with can make some. ($120 or so for the skid row ones$)
I'm not going wheeling (for real) until I have t-case, gas tank and engine skids installed. And wont' do any really rocky trails until I have rails. So until then, I drive a big ol mall crawler that's nekkid underneath. Oh well.
DaffyXJ's Avatar
NAXJA Member #929
Re: Most Important
Several companies offer bolt on LCA skids. Skid row would be an example. http://www.4wd.com/shop/productdetai...roductsku=3305 Easiest way is to cut and tack 1/4" plate over the LCA brackets. I found on my D-30 that the LCA brackets bent well before the LCA took any damage other than scapes.
Got the plate cut but still havent put it on the D-44.
Old March 25th, 2005, 09:48
Citat3962's Avatar
Thumbs up Re: Most Important
nice those look simple enough.. added to the list of things I need to fabricate!
Old March 25th, 2005, 10:16
SharkXJ's Avatar
SharkXJ SharkXJ is offline
NAXJA Member #1177
Re: Most Important
JKS Mini LCA Skids - They have to be welded on but for only $25 who can complain. I had them on the TJ and they worked awesome.
http://www.4x4rockshop.com/scripts/p...idCategory=332
Old March 25th, 2005, 10:37
Dirk Pitt's Avatar
Dirk Pitt Dirk Pitt is offline
Adam Dowling
Re: Most Important
Rocket,
Since we wheel in the same places I'll tell you my experience.
Green and white trails at the badlands will give your rockers a serious workout. I have rock rails, and haven't installed the t-case skid yet.
At winterfest, my rock rails were priceless, however my t-case was fine.
If you can't get both now, I would get the rock rails first and then the t-case as soon as you can.
YMMV.
Old March 25th, 2005, 12:32
loop loop is offline
Re: Most Important
At winterfest, my rock rails were priceless, however my t-case was fine. If you can't get both now, I would get the rock rails first and then the t-case as soon as you can. YMMV
a differing thought........you Jeep can function with a dent in your rockers....it can't with cracked open Tcase. if you happen to find that right rock(or it finds you) your mileage will definitely vary
that said you should get them both ASAP
Old March 25th, 2005, 14:32
Dirk Pitt's Avatar
Adam Dowling
Re: Most Important
This also has a lot of merit.
Old March 25th, 2005, 14:43
Rev Den Rev Den is offline
Re: Most Important
I only use my rails on real tight stuff....it can be avoided at Attica. I would skid the case 1st....and follow quickly with the rails.
Rev
Old March 25th, 2005, 15:00
theslacker's Avatar
theslacker theslacker is offline
Re: Most Important
Depends on how big the dent is
Old March 25th, 2005, 17:36
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Most Important
i personaly am a function over form person - so rock rail's are way down the line...
my T-case, gas tank, and engine/tranny were all covered before my jeep even saw a dirt road (the ONE thing that i have done right the first time)
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old March 25th, 2005, 19:07
woody's Avatar
woody woody is offline
Gone but not forgotten...
Re: Most Important
I think they are all important.
The fuel tank skid (especially teamed with a factory or eq. 2" receiver) makes a pretty solid defense against rear-end collision.
A quality set of rock rails (box or round) will both protect the structure from abuse, but also offers some defense in a broadside collision.
A solid crossmember & t-case (and engine/tranny skid) are normally 'on duty' off-road only...same goes for the LCA skids.
I have OEM tank skids and Rusty's t-case skids on both my XJs, and wish I had installed JKS Super-Nerfs and LCA skids for the stock one before I started wheeling it. After 4 trips afield, my rockers and one LCA bracket are bad hammered.
[CENTER]
[/CENTER]
Old March 25th, 2005, 19:20
w_howey's Avatar
w_howey w_howey is offline
Re: Most Important
I don't have any rock rails. But my rockers are mostly rusted out anyway. I put a cereal bowl sized dent in my gas tank, first time wheeling. Thats why I have a tank skid, and a t-case skid but still no rails.
AMSOIL Independent Dealer
How important is an e-brake? (rear disc swap) MJ_Chubs Modified Tech Discussion 33 June 28th, 2005 05:39
Brc Important Land Use Update (8/30/04) Ed A. Stevens Land Use Forum 1 August 31st, 2004 08:51
How important are sway bars? dandecicco Modified Tech Discussion 26 June 14th, 2004 14:55
Is Moab important to you? Crunch Land Use Forum 19 December 30th, 2003 22:52
Important Info on the upcoming upgrade.... F. F. Non-Tech / Off Topic 5 November 30th, 2003 19:45
