Old March 22nd, 2005, 13:57
wescam's Avatar
wescam wescam is offline
Anyone running Detours XJ Unibody "Rok Slyder"
The URL is here
http://detoursusa.com/xjrokslyders.php
I searched about T-Case skids with this set up, but didn't find the answer here or elsehwere.
I mailed them because I didn't see how other vendors' T-Case skids would work with this product.
The answer was that they are working with a vendor to provide one that's compatable (future product), and/or I could have one fabbed up locally, and/or I could buy a T-case skid, send it to them for mods, then it would work.
I'm asking if people who use this product
-- did you use Detours to fab up mods to your t-case skid?
-- or did you get a local fab shop (or DYI) your own T-Case skid?
-- or do you just run around nekkid with this product installed and no T-case skid...
I know these are kind of costly, but I like them. So I'm trying to figure if they are worth the extra effort/time/cost to get them working with a t-case skid.
Thanks
Old March 22nd, 2005, 22:42
93xjmark 93xjmark is offline
Re: Anyone running Detours XJ Unibody "Rok Slyder"
I picked up just the chassis stiffeners from detours this week. With the recent install of the clayton's longarms, I didn't need the front arm mount portion so he made an un-finished set to my specs.
I will be extending them up to the front shock mount location using 1x3 boxtube. The stiffeners mount to the outside of the "frame" so even the factory t-case skid will work without any modification. I plan on plating the bottom of the rails and stiffeners with a 5"x1/4" cold rolled plate that will protect the rails from rock damage, and serve as a belly skid mount. These will tie into the 2x6 box rockers and then become part of the cage mounting points. Detour's Rokslyders are well worth the money IMO, as the complete system, or as an integrated component of a chassis.
Old March 23rd, 2005, 06:15
wescam's Avatar
Well it looks like your custom stiffeners are about the same (in the area of the t-case anyway) as the stock stiffeners (?)
If so, I can maybe just run a stock or near stock t-case skid. (Unless they just suck, I'll ask around)
Thanks for the reply.
Old March 23rd, 2005, 08:19
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Anyone running Detours XJ Unibody "Rok Slyder"
i ahve a stock t-case skid sitting in my dads garage - it mounts with 4? bolts - 2 on the bottom of the x member and 2 on the bottom of the fraimrail - and should work for your application - PM if interested
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old March 23rd, 2005, 09:54
wescam's Avatar
Yep, that's the reason they are saying they aren't 100 percent compatable with aftermarket skids for the T-Case.
Most of the more beefy ones have an L shaped end that bolts up to the unibody rail (or whatever you call the thing that isn't really a frame rail) both underneath and on the OUTBOARD side.
So that's the conflict. I just dindn't see it before, but I found some more close ups...
Old March 23rd, 2005, 09:58
XJ_ranger's Avatar
another option (not to try to kill our deal) is the x-member mounted skids - like the one from JKS mfg...
http://www.jksmfg.com/hd_x-member.htm
that one runs 300 - not sure if there are cehaper out there...
Old March 23rd, 2005, 14:16
Detour's Avatar
Detour Detour is offline
www.Detoursusa.com
Yup, that JKS skid would work fine.
That skid looks really easy to make as well............for all you home-brewers!
Old March 23rd, 2005, 14:29
jeepguy97's Avatar
jeepguy97 jeepguy97 is offline
On a Time Out
That is terrible grammar.
Old March 23rd, 2005, 15:38
XJCasper's Avatar
XJCasper XJCasper is offline
NAXJA Member #1042
I am too cheap to buy these parts.
XJ Running Bad - Hard Starting & More GSequoia OEM Tech Discussion 3 October 26th, 2004 17:03
Hmm? Should I keep my XJ? Or? MountainGoat Non-Tech / Off Topic 7 October 9th, 2004 01:31
XJ unibody frame mnsgluth Modified Tech Discussion 8 June 27th, 2004 20:38
Parts for sale - XJ, CJ, Ford and Toyota jeep_cj8 For Sale: Private Party Only. XJ ITEMS ONLY 3 April 25th, 2004 13:56
parting out 88 XJ 2wd AzRick For Sale: Private Party Only. XJ ITEMS ONLY 8 April 6th, 2004 15:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
