Old March 22nd, 2005, 08:40
littlexj1 littlexj1 is offline
how important is it?
that little air canister mounted behind the bumper on the passenger side?
Old March 22nd, 2005, 08:52
Hickey's Avatar
Hickey Hickey is offline
Re: how important is it?
search this forum for "Football"
Old March 22nd, 2005, 09:38
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Depends a little on the year, and what you have for accessories. If it leaks, you lose various vacuum-operated functions: cruise control if you have it, front axle engagement if you have a disconnect axle, and heater control functions (heat will always default to defrost). If you simply bypass it, these things will work, but may stop working during low vacuum conditions, such as climbing a hill. This is just when you least want your 4WD to pop out, so if you have a front axle disconnect, fix the canister. On models with cruise control, the canister has two independent chambers, one for cruise and the other for axle and heater, so one side might be bad while the other isn't.
Brc Important Land Use Update (8/30/04) Ed A. Stevens Land Use Forum 1 August 31st, 2004 08:51
How important are sway bars? dandecicco Modified Tech Discussion 26 June 14th, 2004 14:55
Is Moab important to you? Crunch Land Use Forum 19 December 30th, 2003 22:52
Important Info on the upcoming upgrade.... F. F. Non-Tech / Off Topic 5 November 30th, 2003 19:45
