Old March 5th, 2005, 15:41
ang31-0f-d347h ang31-0f-d347h is offline
Wobble of Death
Well im sitting here in front of an 87 XJ...
It has a Rustys 4 1/2 lift on it... at around 40 miles an hour it starts to wobble...
Is this contributed to the support arms ? We believe installing the adjustable arms in the front will fix the problem.
anyone have any advice?
Old March 5th, 2005, 16:27
bigredjeep's Avatar
bigredjeep bigredjeep is offline
Re: Wobble of Death
pm 19904x4 on the first page on the users list. he had the death wobbles like krazy, he replaced some stearing joints and put on tomkin ajustable lower controle arms and they went away (mostly) also get an alignment by someone thats done jeeps before, they set it to the almost exact speces it should be.
Old March 5th, 2005, 16:43
Re: Wobble of Death
yeah the control arms are the things we got...
hmm ok... hopefully ill take a look at it all tomarrow.
Old March 5th, 2005, 18:49
Badcop's Avatar
Badcop Badcop is offline
Re: Wobble of Death
Check the caster/camber of the front end. Check the track bar mounts top and bottom. Check the balance of the tires. Check the allignment. Check all those in the order and youll get it.
Old March 5th, 2005, 19:16
pabloconrad's Avatar
pabloconrad pabloconrad is offline
Re: Wobble of Death
You have to check everything on your front end when you lift your vehicle. Check your tie rod ends, track bar mounts, anything with your steering. Anything that looks or feels a tiny bit loose, replace with new. Then get an alignment.
Did you get a pitman drop arm? That helps your control arm get to the same angle as your track bar and helps eliminate that.
Bonafied death wobble! 4DLVOFJEEPS Modified Tech Discussion 9 February 4th, 2005 12:25
How I ended my Death Wobble + tires for sale PC-UT-XJ Modified Tech Discussion 0 June 23rd, 2004 15:52
Why do they call it death wobble? Nick Modified Tech Discussion 17 January 2nd, 2004 03:23
