Old March 1st, 2005, 14:11
live24wheel's Avatar
live24wheel live24wheel is offline
Question Death Wobble
Sorry to do this to you guys but im sure you will still help me. At various speeds above about 35 any where to about 70, when I hit a bump or anything, it try to throw me into death wobble. sometimes it stays and sometimes it just lasts a second or two. I have Rockkrawler 4.5" front springs, Rockkrawler lower control arms set at 16.5" and the Rubicon Adjustable track bar and the axle and tires are aligned properly. Are my settings on the control arms ok or is it something like a drop pitman arm that I need.
TIA,
Tom
Old March 1st, 2005, 14:20
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: Death Wobble
Drop Pitman isn't needed unless you've changed the trackbar position as well (the RE ones don't). I'd recommend a search about DW after you go out and check the trackbar, control arms and remainder of the front end for looseness or play.
What figures do you have for 'proper' alignment?
Old March 1st, 2005, 14:42
Re: Death Wobble
I measured that the axle was at center by getting the same measurments on each side and did the toe alignment. I was just told that because I have stock uppers that I might need to lengthen the lower arms a little more even, so im gonna try that and see what I get.
Thanks,
Tom
Old March 1st, 2005, 15:08
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Death Wobble
After my call to RE - i found that thier bracket drops the trackbar about 5/8" lower than factory angle - shouldnt matter much, but it may
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old March 1st, 2005, 15:13
Urban Redneck's Avatar
Urban Redneck Urban Redneck is offline
Re: Death Wobble
Click the link...it will give you all the DW answers you need.
Click Me!
Old March 1st, 2005, 15:15
Re: Death Wobble
I just have the regular adjustable trackbar with the heim joint on the body side and poly bushing on the axle end, Not the H.D.
Tom
Old March 1st, 2005, 15:20
RCP Phx RCP Phx is offline
Re: Death Wobble
Here you go again,The RE Bracket places the trackbar "EXACTLY" the same height as a stocker.Quit reading/calling and bust out a tape measure for yourself!
Old March 1st, 2005, 15:53
jbzj's Avatar
jbzj jbzj is offline
Re: Death Wobble
There are so many different things that can cause or contribute to DW that its almost impossible to diagnose over the internet. I couldnt figure out my DW for 3 months, tightened everything down countless times, replaced my LCA's, upgraded my steering, got like 4 alignments and nothing helped. Finally I gave in and took it to good shop near my house and they found a large crack in unibody under my TB bracket (RE). They sleeved and gusseted the unibody and welded the bracket on..since then I havent had a problem. Major PITA though. Also check your steering box too for any leaks or excessive play in the shaft.
Bonafied death wobble! 4DLVOFJEEPS Modified Tech Discussion 9 February 4th, 2005 12:25
How I ended my Death Wobble + tires for sale PC-UT-XJ Modified Tech Discussion 0 June 23rd, 2004 15:52
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
