Old February 26th, 2005, 15:57
wrecklaw71's Avatar
wrecklaw71 wrecklaw71 is offline
unibody strengtheners/use what when?
I have an 01 xj when is it really necessary to install frame/unibody strengtheners? and what brand would you guys recomend.
Old February 26th, 2005, 17:15
wescam's Avatar
wescam wescam is offline
Re: unibody strengtheners/use what when?
I don't know if this is what you mean, but I like the rock slider / unibody brace combo here http://www.detoursusa.com/xjrokslyders.php
I've just been shopping for rock rails/sliders and figure this one (with the brace) is pretty solid.
You can also just buy the unibody brace.
...... just from what I read searching around, people seem to like them (although costly)
Old February 26th, 2005, 17:49
Mike L's Avatar
Mike L Mike L is offline
Check THIS product out from TNT Customs. I wish that would have been around before I plated my frame.
-Mike
Old February 26th, 2005, 19:01
motorcityxj motorcityxj is offline
-Mike
I am glad they came out with it BEFORE i got around to plating mine. HMM finally the cold michigan winter actually saved me some time and agravation on this one. Looks like a winner to me, fair price even. Does anyone here have them yet ?
Old February 26th, 2005, 19:07
wrecklaw71's Avatar
I saw some frame strengtheners in a Rubicon Express magazine made by "currie " anyone seen these?
Old February 26th, 2005, 19:26
XJZ XJZ is offline
What are you trying to accomplish?
These frame sleeves will help protect the frame, but won't help too much as far as the frame flexing torsionally.
Old February 26th, 2005, 21:29
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Really? Care to define too much?
Speak the Truth-Question with Boldness-Speak without fear.
Old February 26th, 2005, 21:51
jrsxj98's Avatar
jrsxj98 jrsxj98 is offline
DILIGAF
care to elaborate.....
Old February 26th, 2005, 22:04
ArcticXJ's Avatar
ArcticXJ ArcticXJ is offline
I think he means that even with the braces, unless the two framerails are tied together with extra crossmembers, they will still flex independent of each other.
Lateral bracing running between the two framerails would exponentially amplify the effect of this product.
Old February 26th, 2005, 22:43
wrecklaw71's Avatar
most of the ones i have seen connect the front lower control arm frame bracket to the front rear leaf spring hangar bracket
Old February 26th, 2005, 23:57
Mike L's Avatar
He means side to side like the transmission crossmember. If you add a couple more braces from side to side that would also help stiffen up the unibody. If you could build a full length flat belly skid that would really stiffen it up. I have seen it done but it is hard to get every thing tucked up in there. To do so means either running no cat/muffler or building some kind of box in the sheetmetal so they can sit higher. JM2C.
-Mike
Old February 27th, 2005, 00:58
MaXJohnson's Avatar
MaXJohnson MaXJohnson is offline
x2, until XJEEPER and others can offer something more than rhetoric to prove you wrong.
The floor pan is already the strongest side of the XJ's torsion box. An X or shear panel behind the rear seat along with reinforcment around the A pillar-roof intersection and other corners in the door openings would do more to stiffen up the chassis
Old February 27th, 2005, 01:05
Mike L's Avatar
I was told sleeving the frame accomplished nothing really other than adding weight. I can understand plating the bottom so it doesn't get to bashed up on rocks but doing the whole outside isn't truly necessary. If you really want to strengthen the unibody then add a cage.
-Mike
Old February 27th, 2005, 01:21
XJZ XJZ is offline
Bingo!
Old February 27th, 2005, 06:41
dline's Avatar
dline dline is offline
cage it.
How much can a unibody take jeepguy97 OEM Tech Discussion 4 January 17th, 2005 21:26
opinions on frames under unibody BUCKYXJ Modified Tech Discussion 13 July 18th, 2004 11:19
welding to unibody... jjvande Modified Tech Discussion 12 December 26th, 2003 13:59
unibody vbjornsson Modified Tech Discussion 11 October 2nd, 2003 06:27
Free 4 door unibody. Plus other crap..OH TPI MJ For Sale: Private Party Only. XJ ITEMS ONLY 1 July 14th, 2003 14:53
