Old February 26th, 2005, 10:52
kee kee is offline
XJ Front Driveshaft Lengths...
Is there a chart or a website out there somewhere that has the different lengths of factory XJ driveshafts with the different drivetrain configurations over the years?
I'm looking for a driveshaft to throw in my YJ. It has a D44 front axle and a NP231 from a '92 Blazer. Sitting at normal height it has a measurement of 34" from u-joint cap to u-joint cap. I don't mind shortening a driveshaft if I can find one that is longer than I need, but I would rather not lengthen one if I don't have to.
I found that a '97 XJ driveshaft from a 4.0/AW4 was 32" fully extended from U-joint center to center.
Well, back to the garage. I got a cooling fan to install in the YJ today and my new rear bumper brackets for the XJ. I also need to get under the hood of the XJ and figure out what pulley is screaming at me before something locks up....
Old February 26th, 2005, 10:59
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: XJ Front Driveshaft Lengths...
my shaft from a 92 XJ with an ax-15 and a 231 (4.0L) measures 29.5" compressed to 32.5" extended ujoint center to ujoint center...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
front driveshaft question DaltonXJ OEM Tech Discussion 2 February 15th, 2005 23:26
RE 3.5 Lift from a TJ - Will the front swap over to an XJ? SharkXJ Modified Tech Discussion 3 February 2nd, 2005 23:47
front driveshaft vibes A_J OEM Tech Discussion 2 January 20th, 2005 13:53
Front driveshaft compression travel available? SV1CEC Modified Tech Discussion 5 April 9th, 2003 22:13
