Old February 2nd, 2005, 22:05
SharkXJ's Avatar
SharkXJ SharkXJ is offline
NAXJA Member #1177
RE 3.5 Lift from a TJ - Will the front swap over to an XJ?
Hi, I did a search and just about went blind reading all the posts, so sorry if this has been asked before. I currently have a 97 TJ with the RE 3.5" lift installed, Front Adj Track Bar and JKS Quik Disco's. I just bought a 2001 XJ and I am selling the TJ then my plans are to lift the XJ.
So my question is, can I take the front end components from the TJ lift (LCA's, Adj Track Bar and JKS Disco's) and use them on the XJ? I have been told the front Suspension is the same on an XJ as it is a TJ.
Then all I would have to buy is Leaf Packs for the rear.
What do you think?
Old February 2nd, 2005, 22:30
xjj33p3r's Avatar
xjj33p3r xjj33p3r is offline
NAXJA Member #1108
Re: RE 3.5 Lift from a TJ - Will the front swap over to an XJ?
I believe the suspension is the same, other than the springs. The front ones will give 1" less than advertised for your xj. I believe that's how it works out.
Old February 2nd, 2005, 23:23
orvpark's Avatar
orvpark orvpark is offline
NAXJA Member # 1374
you'd probably get more for the tj springs together. I'd sell the springs on ebay, keep the rest and buy all new springs for the xj
Old February 2nd, 2005, 23:47
Gojeep's Avatar
Gojeep Gojeep is offline
I done a few XJ's now with TJ suspension and it depends a lot if the TJ springs were HD ones or not and if you are running a heavy bumper and winch on the XJ. I have got the same lift from TJ HD springs when the XJ did not have the extra weight up front. Used the shocks etc as well but do measure the compressed length of them to make sure they compress to the same length as the stock XJ shock. I had to add a hockey puck to one so I could run them as they were 20mm longer when compressed.
Stuff, XJ and TJ desertjeeper For Sale: Private Party Only. XJ ITEMS ONLY 8 December 27th, 2004 16:46
IN/OH/PA -> 88 XJ Parting out...PICTURES and SOME FREE JUNK! TheGirlfriendYJ For Sale: Private Party Only. XJ ITEMS ONLY 2 November 30th, 2004 16:16
CA: Front Dana 44 High Pinion Project - 4.10, Lock-Right, 5-760X U-joints, XJ, TJ, ZJ BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 0 October 27th, 2004 14:52
Jeep Front Dana 44 High Pinion - 4.10, Lock-Right, XJ, TJ, ZJ BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 0 January 8th, 2004 19:48
6.5" lift front coil springs Getcha_Sum For Sale: Private Party Only. XJ ITEMS ONLY 3 December 6th, 2003 17:36
