Old January 19th, 2005, 21:53
A_J's Avatar
A_J A_J is offline
front driveshaft vibes
Possible Dumb Question Alert:::::::
90 XJ, 3.5 inch lift, np 242, SYE, TW rear shaft, 4 deg shims on the rear
I have some vibes that I'm sure are coming from the front shaft (I took off the shaft and the vibes went away) now I want to know what to do next.
After the lift and SYE I had to shim the rear axle to stop the rear driveline vibes. Could the font shaft be having the same issue? I didn't shim it b/c I hadn't read anywhere that I needed to, but I'm thinking that might be the problem.
The shaft is off the jeep now b/c I am replacing the u-joints just to rule that out, so I don't have the angles on the front. It *looked* ok, but I didn't measure so I'm not 100% sure.
So I guess I have two questions:
1) Has anyone had to shim the front axle after a similar lift (3.5")?
2) Am I doing any damage to the front diff by running without the front shaft in place? I don't plan to leave it for more than a couple of days, but I want to be sure I'm not screwing anything up.
thanks in advance for the help.
Old January 20th, 2005, 02:39
luvdaxj's Avatar
luvdaxj luvdaxj is offline
Re: front driveshaft vibes
You won't do any damage by not having the front driveshaft in. I've never heard of shimming the front axle. How bad were the U-joints? That could be your problem.
Old January 20th, 2005, 14:53
A_J's Avatar
A_J A_J is offline
U-joints were pretty good actually, so that's why I think the shims may be needed. The CV joint U's looked like they hadn't been lubed in a while, but otherwise ok, so I'm not going to replace them just lube them up.
XJ front driveshaft with 242 SYE? baseballneal86 Modified Tech Discussion 10 August 14th, 2007 05:18
front driveshaft vibration... BillR Modified Tech Discussion 24 April 26th, 2005 11:47
Front driveshaft question... nosajwp OEM Tech Discussion 2 December 29th, 2004 06:21
New T- Case and Front driveshaft install HELP !! Silverstreak01 Modified Tech Discussion 1 April 23rd, 2004 16:17
front driveshaft problems shizza-my-nizza Modified Tech Discussion 5 September 8th, 2003 00:20
