Old November 7th, 2004, 11:57
BUCKYXJ's Avatar
BUCKYXJ BUCKYXJ is offline
ok cut out the rear quarters now what do I do with it?
cut rear quarters out and the rear fenders out some more gotta go flex it out now to check clearance. Poser flex shots with the 36s too. Crappy cam= crappy pics
Old November 7th, 2004, 12:56
MuddinXJ's Avatar
MuddinXJ MuddinXJ is offline
Re: ok cut out the rear quarters now what do I do with it?
cut some more damnit. hell you dont need that front fender at all. i will post pics of mine later(its nekked right now). the rear looks good put you need to weld something up in there to keep shit from flying in.
Old November 7th, 2004, 13:27
BUCKYXJ's Avatar
im planning on welding it just not yet
Cut & Mounted TJ flares (pics) BskisXJ Modified Tech Discussion 3 September 4th, 2004 06:36
Wanted: the two small brakets that hold the rear U joint to rear diff on 90 xj lapaul Wanted: Private Party Only 1 July 18th, 2004 18:21
Oil Pan Leak @ Rear Main Seal - Long Post Chippo OEM Tech Discussion 6 June 7th, 2004 19:11
Chopping the rear Quarters Matt99XJ Modified Tech Discussion 24 February 25th, 2004 23:11
Help I installed a RE 3.5" Lift with rear spring packs now I have vibrations Augidogi Modified Tech Discussion 2 May 4th, 2003 00:20
