Old September 24th, 2004, 19:26
hadAjeep's Avatar
hadAjeep hadAjeep is offline
automatic trans question
will these jeeps with an automatic trans idle up hill in 4 low? The only experince I've had with an auto is in my charger and it won't idle up a steep incline, just sits there and slips. Stupid question but I need to know
Old September 24th, 2004, 19:34
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: automatic trans question
Nope.
Torque converter isn't locked in low gear at idle. It'll slip just like any other vehicle.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old September 24th, 2004, 19:38
hadAjeep's Avatar
Unhappy Re: automatic trans question
Well that freakin sucks. Does it roll backwards then? Only reason I ask is because the automatics are everywhere and 5 spds aren't. I'm looking to buy an XJ and don't really want an auto. Now I want one even less
Old September 25th, 2004, 10:40
scoobyxj's Avatar
scoobyxj scoobyxj is offline
Inlighten me as to why you think you cant just give it a little throttle to climb the hill.
Old September 25th, 2004, 16:10
Sarge Sarge is offline
Depends. My 2wd XJ will just sit there on a slope with the tranny in drive and not giving it any gas. My van will roll on back on ya.
Sarge
Old September 25th, 2004, 18:46
hadAjeep's Avatar
I'm not saying I can't give it throttle. I'm just used to 5spd where when I put it in gear, it moves. I've just never wheeled in an auto before.
Old September 25th, 2004, 19:17
8Mud's Avatar
8Mud 8Mud is offline
Saw a guy the other day had a switch, spring loaded up (momentary lock), normal tip down (stayed locked) normal drive in the middle, under his T shifter, could lock his converter at will, in any gear. Pretty easy to do, but really donīt know how it will affect the AW4, over time.
Youīll find out it has itīs pluses and minus, not having to clutch and shift in deep mud or sand helps on occasion. Not to mention being able to keep both hands on the wheel much more. Though I do miss the compression braking on occasion, with a standard automatic.
I spend most of my off road time, on muddy trails, manaul shift, hurts more than helps.
Old September 25th, 2004, 19:46
hadAjeep's Avatar
What about manual valve bodies for the AW4? I've got one on my duster and it enables compression braking in any gear. I don't hate auto's, just not sure if they're what I want for wheeling. But since alot of you guys seem to like them, maybe it'll be ok.
Old September 26th, 2004, 12:59
Steve88XJ Steve88XJ is offline
you could always try to override the lockup converter in 2nd gear in 4wd low and see what happens
http://www.steve88xj.com/aw4
Old September 27th, 2004, 07:19
techno1154's Avatar
techno1154 techno1154 is offline
Actually, even in 2H on all but the steepest hill I could take my foot off the brakes and the XJ would not roll backwards unlike some other American made vehicles I have driven.
I am not sure of the answer you are expecting. My theory is simply keep your foot on the brakes; use one foot on the brakes and one on the gas (I do not think this is a very good practice) or increase the gas a little until the XJ holds on the hill.
My $0.02
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old September 27th, 2004, 14:11
jeepguy97's Avatar
jeepguy97 jeepguy97 is offline
On a Time Out
My XJ will crawl up a hill at idle in 4lo. My buddies Auto Wrangler will too.
Old September 27th, 2004, 14:22
Jackhill442 Jackhill442 is offline
obviously it depends on the steepness of the hill. It won't crawl up a really steep hill but a moderate hill, yes.
Old September 27th, 2004, 14:53
hadAjeep's Avatar
Are there any major changes to the AW4 over the years? Right now I'm going look at a 96 cherokee auto. 92,000 miles and the ad says mostly used for commuting.
Old September 27th, 2004, 18:08
jeepguy97's Avatar
On a Time Out
Yea it does depend on the hill. I should have been more clear it will climb up a moderate hill, but it won't just crawal up the side of a mountain as you may expect, however it won't really roll backwards as much as other vehicles either.
4 wheel drive release question?? Lewis OEM Tech Discussion 12 May 14th, 2006 09:27
Auto trans question (Non-Jeep) copperhead Tow Rigs and Trailers 0 April 26th, 2004 05:02
I know I'm stupid, but....(trans question) banjos=underrated OEM Tech Discussion 10 January 6th, 2004 13:11
Trans leak??? 96country OEM Tech Discussion 14 December 10th, 2003 11:32
Headers Question Garthbmn7 Modified Tech Discussion 1 December 6th, 2003 06:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
