Old September 12th, 2004, 10:15
Roxtar's Avatar
Roxtar Roxtar is offline
Automatic trans not shifting
Yesterday at the Badlands my transmission ('99 AW4) quit shifting while in drive. I didn't notice it for a while due to staying in 4lo and 1/2 gear all day.
If I put it in drive it just stays in overdrive. Manually shifting through the gears works fine so the gears are there, it just won't shift through them by itself. The check engine light lit up and AutoZone showed a code P1698. This number doesn't show up in their computer, though.
Ideas?
Old September 12th, 2004, 12:16
herreraxto's Avatar
herreraxto herreraxto is offline
Re: Automatic trans not shifting
This happen to me and the problem and was the tps sensor, fail because i washed the engine, but whit the only difference mine is a 90 limited unles we have the same tps desing
Old September 12th, 2004, 14:25
PearlCountry PearlCountry is offline
Did a google search, here are the results from two different sites. Both point to the TCM. Might try checking the cabling first.
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
P1698 No Bus Message From TCM (Chrysler, Jeep)
Good luck.
Auto trans not shifting..... Gil BullyKatz OEM Tech Discussion 9 April 30th, 2004 06:16
AW 4; 1&2 gear shifting characteristics? shugener OEM Tech Discussion 2 March 8th, 2004 04:45
Automatic trans shift controler Ed Wulfe+ Modified Tech Discussion 1 January 5th, 2004 20:59
Trans leak??? 96country OEM Tech Discussion 14 December 10th, 2003 11:32
Hard Shifting Hawaiian Style OEM Tech Discussion 0 December 8th, 2003 16:15
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
