Old May 8th, 2003, 12:02
LAWNMAN323's Avatar
LAWNMAN323 LAWNMAN323 is offline
Location: Lansing, MI (school), Charlevoix, MI (summers)
overextended caliper piston, how to compress?
I accidentally pumped my brakes when my front caliper was off the rotor with no pads on it, so the piston is fully extended, I can barely fit the rotor in the opening, let alone 2 pads.
When I compress the piston with the bleeder screw open, I feel binding in the piston.
How do I compress it? Thanks.
Old May 8th, 2003, 12:11
Mike L's Avatar
Mike L Mike L is offline
A c-clamp usually works well to compress it back down.
Old May 8th, 2003, 12:31
LAWNMAN323's Avatar
I tried that, with a piece of flat steel accross the piston to keep it straight - I can't get enough leverage on the c-clamp to compress it. the piston is fighting me too much.
Old May 8th, 2003, 12:34
tlman's Avatar
tlman tlman is offline
NAXJA Member #20
Remove the cover from the master cylinder and scoop some fluid out so that it doesn't overflow as the fluid returns from the wheel. Crank the clamp slowly so that it doesn't flow back like a fountain and get fluid everywhere.
Old May 8th, 2003, 12:44
Mike L's Avatar
You took the words right outt'a my mouth!
Old May 8th, 2003, 13:02
AZ Jeff's Avatar
AZ Jeff AZ Jeff is offline
You may have the piston so far out of the bore of the caliper that it's cocked in the bore. Pushing now will only aggravate the problem. Make sure that the face of the piston is PERFECTLY PARALLEL to the plane of the disk before using the C-clamp.
Old May 8th, 2003, 19:36
LAWNMAN323's Avatar
Thanks for the help, guys - I took it to my local shop and I had it crooked, they straightened it out for me for free.
Live and learn I guess!
sticking caliper ReBeL XJ OEM Tech Discussion 7 November 18th, 2003 06:59
What does the brake caliper thread into? xj92 OEM Tech Discussion 12 November 17th, 2003 12:32
WJ caliper brackets on early XJ D30? ScottRoz Modified Tech Discussion 5 October 30th, 2003 12:07
Bolts on front brake caliper! Ghost OEM Tech Discussion 4 August 11th, 2003 21:40
rear caliper w/e-brake hook up mcconnaughey Modified Tech Discussion 1 March 30th, 2003 08:21
