Old August 9th, 2004, 17:55
Brian Felts's Avatar
Brian Felts Brian Felts is offline
Angry Death wobble
Help I am in death wobble hell.Im getting ready to install a 3 inch rough country lift but Ineed to adress this problem first.Is it possible my RE 1.75 spacers are causing this?
Old August 9th, 2004, 18:00
y2kxj's Avatar
y2kxj y2kxj is offline
Re: Death wobble
you haven't loosened anything yet? Check your track bar for play by having someone turn the wheel back and forth while you look at it. Any play is bad. Is it alligned? Pull off your stock steering stabilizer. Does it have much resistance? I personally would figure in a heavy duty steering stabilizer with the lift after my bad DW experience which was solved by that cheap mod alone.
Old August 9th, 2004, 20:28
Re: Death wobble
I have a rancho 5000 steering stabilizer.Seems pretty tight.Stabilizer is less than a year old.Ay experience w pro comp es 1000 shocks?
Old August 9th, 2004, 21:00
RCP Phx RCP Phx is offline
Re: Death wobble
Steering dampner's are a major "Band-Aid"(most early vehicles dont even use them)!Look towards the trackbar and control arms!Good time for an up-grade!
Old August 9th, 2004, 21:05
jeepinmike jeepinmike is offline
Re: Death wobble
Good front end alignment.
Mike
Old August 9th, 2004, 21:49
Y2K-XJ's Avatar
Y2K-XJ Y2K-XJ is offline
Re: Death wobble
Could be your Caster! if everything else is in good condition and within spec I make Lower control arm shims that adjust caster here check it out!
http://www.naxja.org/forum/showthread.php?t=27355
Old August 26th, 2004, 10:36
d0nnyg77's Avatar
d0nnyg77 d0nnyg77 is offline
Re: Death wobble
I am having a similar problem with my 2000XJ. I have a Rusty's 3" lift and 30's. Steering damper is leaking. Will be ordering a new one this weekend. Just received a Rusty's heavy duty track bar with lowered track bar bracket. Super beefy. Instead of the ball joint end, it has the eyebolt socket. I will install it this weekend and let you know how it feels. The XJ rode great with the new front coils, but when I put in the 2" front spacers to level the truck, I got the Death Wobble something feirce. Took the spacers out and it still does it. Hoping this will cure the problem. Been too nervous to drive on the highway for almost 2 months now. Any other suggestions will be greatly appreciated. Will be in touch.
D
Old August 26th, 2004, 11:00
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Re: Death wobble
Look at all the bushings as loose bshings can be a cause of your wobble.
Old August 26th, 2004, 11:09
family XJ family XJ is offline
I have not Confirmed, or I used a BAD email Addy
Re: Death wobble
I have had this happen to me twice. The first time I was completely stock and it started. the tires had a broken belt inside or something like that. I lifted my Jeep(coil spring, and AAL only, no shocks or anything) and put on new swampers and it stopped. Then the swampers wore unevenly and it came back bad. So i replaced the control arms with poly bushings tie rods and ball joints and it was still there. Then I got new tires and it went away. My suggestion is to try someone elses tires if you can or if yours need replaced this may be the time. HTH
Old August 26th, 2004, 12:34
Stick's Avatar
Stick Stick is offline
Re: Death wobble
Check your control arms...maybe one of them is bent or the bushings are bad.
Old August 27th, 2004, 08:32
Angry Re: Death wobble
reballaced the tires istalled the liftand it stopped doing it just going down the road.however when you step on the brakes at about 50 it will skake so bad it will make you crap your pants.my new 8 inch rims seem to amplify the problem.
Old August 27th, 2004, 09:41
ChuckD's Avatar
ChuckD ChuckD is offline
Re: Death wobble
To all you guys with DW. Did you get an alignment? If so post your numbers. If not, then that's where you need to start.
How I ended my Death Wobble + tires for sale PC-UT-XJ Modified Tech Discussion 0 June 23rd, 2004 15:52
Death wobble Q's XJEEPER04 OEM Tech Discussion 28 August 18th, 2003 17:47
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
