Old August 1st, 2004, 21:03
lindsj lindsj is offline
On a Time Out
Question No death wobble on the new lift, but...
Hang with me here, I'm a newbie to this stuff.
I installed Rusty's 3" lift on my 2000 xj last weekend. He told me I would probably need the tc drop. I tested it out without the drop, and no vibrations but I was getting a noise at all speeds when I would press on the gas or let off. Sounded like a grinding coming from the rear.
I then installed the drop, and now I only get the noise at speeds above 65 mph.
Can somebody tell me what the noise is, and what I'll have to do to fix it, or if I can just live with it. Thanks in advance.
Old August 1st, 2004, 21:40
Blair Williams's Avatar
Blair Williams Blair Williams is offline
Thumbs down Re: No death wobble on the new lift, but...
The noise is probably the yoke of the driveshaft hitting itself as it spins because it is at such an extreme angle. I read somewhere here in the past couple of days that the newer xj's were more susceptible to this, so your 2000 is a likely candidate. I dont know what kind of damage it would cause to drive it like that for a while, but i would look into getting a slip yoke eliminator (SYE).
bigger lift, now what??? tommy1102 Modified Tech Discussion 9 March 9th, 2005 08:15
How I ended my Death Wobble + tires for sale PC-UT-XJ Modified Tech Discussion 0 June 23rd, 2004 14:52
NC: Major parts for a 4-5 inch lift + 5 31" MTRs on 15x8 767s Scriff For Sale: Private Party Only. XJ ITEMS ONLY 12 December 14th, 2003 18:06
