Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old July 30th, 2004, 09:25
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Just installed a FlowTech "Red Hot" muffler, and it sounds great!.
This is the third muffler I've had on the XJ in as many months. The Moroso and Imco were much too loud, so in disgust I installed a "Red Hot" made by FlowTech. It's a glass pack style, but with a difference. It has a louvered core, that's designed with a spiral pattern to give a twist to the exhaust gas flow. It has a unique deep sound; more like a chambered muffler than a glass pack, but without the droning at highway speeds.
It's definetely increased the low end torque, and should increase the mpg a little too. Very good muffler for the price......
Old July 30th, 2004, 11:11
Darky's Avatar
Darky Darky is offline
Re: Just installed a FlowTech "Red Hot" muffler, and it sounds great!.
how much was it?
Old August 1st, 2004, 06:15
REDXJ4FUN's Avatar
REDXJ4FUN REDXJ4FUN is offline
I have not Confirmed, or I used a BAD email Addy
was the moroso the spintech version?
Old August 15th, 2004, 21:05
Sorry about the time lag to answer; been out of town.
BlackSport, the RedHot was only $17.95 from Summit Racing. I see them even cheaper on eBay. It seems strange, but the muffler has "mellowed out" over the last couple weeks. It has a deeper, smoother tone than when I first installed it. Don't know why, maybe it's my ears??? LOL. For a glasspack, it's an excellent muffler.
RedXJ, the Moroso is called a "spiral flow". It has a spiral baffle around an open core that you can see through. They are supposed to accellerate the exhaust gases through the muffler. The XJ had good performance with it on, but man, was it LOUD. Couldn't stand it, so I replaced it with the RedHot.
The IMCO is a copy of the Flowmaster single chamber, and it was loud also. I had considered installing them both together, just to see how it sounded. Both together would probably have gotten the noise down to a bearable level. It would have taken a lot of pipe modification however, so I just went with the RedHot.......
Old August 16th, 2004, 05:47
scoobyxj's Avatar
scoobyxj scoobyxj is offline
did you notice any change in performance with red hot?
Old August 16th, 2004, 09:19
Scooby, yes it has a lot more pep with the RedHot. It was about the same performance gain as I got with the Moroso and IMCO, but with a quieter tone.
I have a small dip in front of the garage where I park. With the stock type muffler, I had to give it some gas to start it into the garage. With the RedHot on, I don't have to touch the accellerator at all to get it to move into the garage. This tells me it has more torque even at idle, than it did with the stock type muffler. (My stock muffler was long gone, but it still had a "stock type" on when I changed it. Those mufflers must be really restrictive........)
Old August 17th, 2004, 13:28
Jeepenstein's Avatar
Jeepenstein Jeepenstein is offline
I went with the 3 chamber flowmaster, a high flow cat and had all new 2 1/2" pipe run all the way back, it cost me a little bit but not real bad considering the cost of "bolt on" kits.. sounds great and after 40K on it ti still sounds a s good as when I put it on.. dunno about power though, I am sure it made a diference but I made a lot of other changes at the same time so it is hard to single it out..
BUBBA
Old August 17th, 2004, 17:57
Darky's Avatar
Sounds like a good deal, I've been thinking about Flowmaster for a while because of the sound. But I may go for this one cuz of the price...
Old September 1st, 2004, 17:29
Centrevillemx Centrevillemx is offline
What are the chances that will pass MD State Inspection?
Old September 1st, 2004, 18:18
Darky's Avatar
depends how strict MD is...if its 50 state certified then it'll pass, that's you have to look for if your state is strict (like CA)
Old August 12th, 2005, 22:34
mrbill3's Avatar
mrbill3 mrbill3 is offline
So do you still have the "Red Hot" on your rig and do you still like it? or did you remove it and why and what set-up do you have now if you did change it?
Old August 13th, 2005, 12:02
bajacalal bajacalal is offline
RunninOnEmpty:
Its probably not your ears, mufflers will often "mellow out" with use as carbon builds up in there.
Old August 16th, 2005, 14:36
Arrow Re: Just installed a FlowTech "Red Hot" muffler, and it sounds great!.
Mr Bill, I no longer have that XJ, much less the muffler. Alas, I let the wife drive it one day, and it was too loud for her. I switched the RedHot for a Thrush Turbo. The Turbo was quieter, it still gave good performance, and the cost was only about $20.
I still have the RedHot in the garage, and am considering using it on my 'new' 96 XJ, maybe in series with a resonator of some kind to quieten it down.
Yeah Baja, you're probably right about the carbon. I've noticed that on several mufflers; the tone seems to change after a few weeks. Actually they seem to sound better, with a smoother tone than when first installed......
Old September 8th, 2005, 22:58
XplodJeepster's Avatar
XplodJeepster XplodJeepster is offline
on the whole - a redhot muffler is a good idea for a person with bad hearing and a loud stereo?
Old September 10th, 2005, 18:18
xjbmx's Avatar
xjbmx xjbmx is offline
I loved my red hot it sounded great without being way too loud. It was tough as hell too.
Rate This Thread:
