Old July 28th, 2004, 20:06
LiveWire Jeeper's Avatar
LiveWire Jeeper LiveWire Jeeper is offline
No-start/No-crank on 89 XJ
Just need a second opinion here. I have an 89 XJ with a 4.0L that's my daily driver. She's been running fine up until this afternoon when I was put running an errand, shut the truck off, and was not able to restart her.
Checked a bunch of things and what it comes down to is when the ignition switch is turned to "start" I don't see 12 volts on the green signal lead to the starter. I'm thinking that my less-than-one-year-old starter module is toasted from an unfortunate pressure-washing of the engine bay. Before I go and shell ount for another one, can anyone suggest any other possible causes or things to check?
Many thanks in advance!
-lw
Old July 28th, 2004, 20:13
jneary's Avatar
jneary jneary is offline
Re: No-start/No-crank on 89 XJ
sounds like the neutral safety switch crapped out. sometimes when that happens, it may start in neutral. also try moving the shifter up and down and then starting.
Old July 28th, 2004, 20:21
Err . . . there's no NSS on this beast. It fell apart in my hands while fixing another problem, and has been jumpered out of circuit since.
Old July 28th, 2004, 20:30
jneary's Avatar
are you geting current out of the ignition switch?
Old July 28th, 2004, 20:44
I can hear the module closing and I get 12v out of the 'other' output terminal, but the output terminal that the starter signal lead is connected to shows no voltage when the ignition switch is at the 'start' position. I've confirmed the starter is good and the CPS is not the issue by applying 12v to the signal lead on the starter direct from the battery with a pair of jumper cables. Under these circumstances, the engine starts and runs fine.
Old July 28th, 2004, 20:51
jneary's Avatar
somwhere between the ignition switch and the starter, there is probably a break in the green wire that engages the starter or the ignition switch at the base of the column is bad. check for melted wiring at the switch.
Old July 28th, 2004, 20:57
Thanks, will do!
Old July 28th, 2004, 21:49
old_man's Avatar
old_man old_man is offline
Sounds like a bad starter relay.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old July 28th, 2004, 22:54
That's rather what I suspect too. I replaced the starter relay shortly after I bought the truck last fall, but last week I pressure washed the engine bay to clear away the product of a couple of nasty oil leaks and I'm thinking I either got some degreaser or water on the relay inadvertantly and fried it.
Now where did I put that spare . . . . .
Old July 29th, 2004, 19:19
Was in the process of pulling the relay out this afternoon and found that the black lead in the bottom corner under the stud had popped off. Stuck it back on and tried the key and she started right up. So alls well.
Funny thing though. When I tried to run down a replacement from a couple of local jobbers, I got all kinds of funny looks and "go to the dealer" suggestions. I would have thought this being a Motorcraft relay that they would be readily available. Anyone have a lead on a generic part number for this part?
XJ Parts srkruger Wanted: Private Party Only 1 November 28th, 2006 09:42
95' stock xj in NorCal for sale--make offer Big Red For Sale: Private Party Only. XJ ITEMS ONLY 2 December 18th, 2003 17:57
zj steering on xj 90xjDave Modified Tech Discussion 2 December 7th, 2003 02:03
D35 4.10 powertrax locker extra shafts from an XJ, YJ JET455 For Sale: Private Party Only. XJ ITEMS ONLY 0 December 6th, 2003 10:22
Lots of XJ, TJ parts TheHighHeat For Sale: Private Party Only. XJ ITEMS ONLY 2 July 12th, 2003 21:21
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
