Old July 26th, 2004, 10:31
joey99jb's Avatar
joey99jb joey99jb is offline
Unhappy Code Scan => P0463 Fuel Level Sensor A Circuit High Input
So this the error I am aparantly getting. I knew that my fuel guage has not been working, it switches back and forth from the correct level to empty.
I am trying to install a chip and I was wondering:
(1) If this was the cause of my chip producing a "check engine" light followed by my car stalling everything I try to start it up with the jet chip. (stage-2)
(2) Is there a way to fix this problem?
Joey B
Fuel Pump Relay Haywire? secutores OEM Tech Discussion 11 September 17th, 2009 01:31
'Question about high ATF level . . . Don Becker OEM Tech Discussion 5 June 17th, 2004 17:57
leaking fuel injectors,i think? dolemite OEM Tech Discussion 12 December 18th, 2003 16:23
TPS Experts. I have high voltage input. LynchMob OEM Tech Discussion 4 December 4th, 2003 07:45
Gas Gauge one 1999 XJ Manuel OEM Tech Discussion 4 April 15th, 2003 17:15
