Old July 19th, 2004, 15:33
fatkidoutdoors fatkidoutdoors is offline
cheap build up question
I have a new xj and wanted to know if any of you have ideas on cheap upgrades. I have 1000 dollars so here we start. It is a stock 89xj laredo 4 door. I have access to some new tires and rims for 550 the problem they are 33's so want to know what lift and backspacing I need to run them they are good tires and the rims are the black rock crawler just the cheap steal ones. The tires are goodyear mtr. so pretty good considering they are brand new. dont know what size lift I would need but obviosly dont have the money vor a sye and lift with the tires so here lies my prob. I know there is trimming involved not woried on that. I also and not going to do major flexing at all this is more my hunting rig and drove it everywhere I would use it this weekend with no probs at all. so more for some clearance issues and the mud. hope this helps and thanks in advance
Old July 19th, 2004, 15:38
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: cheap build up question
Sounds like a good deal on the tires and rims, but you've got more than $450 to do to get your Jeep to a point where you can best make use of those. Instead, I'd recommend using the $1000 for a Budget Boost, 30x9.50 tires that will fit on the stock rims, and then wheel it. Use that to learn what the Jeep is capable of, and after you've built up confidence and ability you'll have a few hundred dollars seed money toward a taller lift, SYE, axle(s) and most importantly, armor.
Old July 19th, 2004, 16:05
Eddie G.'s Avatar
Eddie G. Eddie G. is offline
<- My Grocery Getter :)
You need somewhere around 5.5 to 6". You can find used stuff here and there. But the problem just starts here. You also need to re-gear, make sure your axles are up to the ask of heavier duty workout without snapping, make sure that your steering works correctly. You may even need SYE.
For the budget you have in mind a 3.5"-4" of lift and 31s should be your limit. You may be able to get by without regearing, but you may still feel it. Use the money to get quality parts (full leaf packs, full coil springs, better control arms) and do it right the first time.
Old July 19th, 2004, 16:07
xj92's Avatar
xj92 xj92 is offline
Or just use the $450 you have left over to get a 3.5" lift. That, trimming, and extended bumpstops will fit 33's.
Old July 19th, 2004, 16:09
87CherokeeChief's Avatar
87CherokeeChief 87CherokeeChief is offline
he just said this is his hunting rig and its mostly for mud clearance. Dont worry about much armor with 33's, maybe a tcase skid. As for what lift, you can fit it on 4.5 with about 4" backspace maybe a little more or less, others will tell you more on that. if your not worried about flexing, then you could prob take off the stock flares and trim and if you need to stay legal find some TJ flares. If you do the 4.5" lift you probably wont need an sye, and if you get some vibes just do a Tcase drop and shims, if your not worried about losing about an inch or less ground clearance. If you do the tcase drop a tcase skid would be helpful. As for what brand lift...depends on your money. RE being pretty high quality but also expensive. Then there other stuff like Rusty's which some like and others dont, that is a little cheaper. Also for less than 500 bucks you could go on ebay and buy a rough country lift...its all dependant on the budget.....hope that helps ya man.
Old July 19th, 2004, 17:00
lankchevy lankchevy is offline
hey if the tires are new then u found a steal there, since it is an older xj you shouldnt have to worry about having vibes until u get around the 5 or 6 inch mark, that is if your lucky anyway, i just lifted my 88, 5 inches no sye, no vibes whatsoever. im running 33 12.50s and the only trimming ive done so far is on the rear of the front fender, ive still got the flares on it, i just drilled a new hole a few inches farther back and bolted the flare on then trimmed the body about an inch and a half back. i only rub on the front on the front fender flare when im stuffed and turning, that should be fixed when i trim the front flares level with the bottom of the headlight bezels.
kolby
Old July 19th, 2004, 18:22
Drake00XJ Drake00XJ is offline
Arrow Re: cheap build up question
For your budget an ebay Rough Country lift of 4.5" is the best way to go.
Try these links for Rough Country:
http://cgi.ebay.com/ebaymotors/ws/eB...tego ry=33585
This link is the best, it is a 5.5 RE lift with Pro Comp shocks. At currently $300 this is a steal, you could use the extra cash for any driveline problems, but it comes with a t-case drop.
Any of these lifts would be good options, they all inlude a t-case drop. Some of these lifts have free shipping others don't. If you don't have an ebay account, get one, it is free. Ebay will be a great source for cheaper aftermarket parts for your XJ. Let me know if you need help with ebay, I have been using it for a while. !!!!!My vote is for the last link, it is RE and has shocks and a tcase drop, and some great extras, plus only $100 for shipping to your door. Try to win that before someone else does!!!!!
Old July 20th, 2004, 10:37
going 3.5 lift and trimming want to cog low going to eventually switch out axles once they blow up. cant pass up on tires so going to trim the hell out of it we will see how it comes out
Old July 20th, 2004, 10:45
xjrugger xjrugger is offline
find a lift on ebay or the for sale forum here and try to do a 4.5 if u can. Then just cut the hell out of the fenders and even with stock axles u should be fine as long as you dont get to serious with the throttle around rocks and stuff like that. At 4.5 u might be able to get away w/o the SYE kit.
Old July 20th, 2004, 10:51
myjeepsbigger's Avatar
myjeepsbigger myjeepsbigger is offline
www.cheapxj.com
Old July 20th, 2004, 15:05
Nay Nay is offline
You have a problem with 33's: gears. Stock gears are going to be no fun in the mud with 33" tires. Compensate with the skinny pedal and the D35 is prone to deconstructing itself in a messy fashion.
I'd go for a 2" budget boost and keep your swaybars on. With the $350 you have left, try to find an 8.25 with 4.10 gears and a D30 with 4.10 gears and 297 u-joints. If you can find them locally, trade your axles. You might just stay in your budget, and then you'll have plenty of axle for your usage with enough gearing for 33's, and enough lift with trimming and swaybars connected to clear those tires.
Nay
Old July 20th, 2004, 15:31
u can run 33s with the stock gearing, its liveable but in no way is it great. in 4low when wheeling its not bad at all, yes im sure it would be ALOT beter with 4.56s or 4.88s but u can live with it for a while.
kolby
Old July 20th, 2004, 21:19
csr_011's Avatar
csr_011 csr_011 is offline
Check out Rustysoffroad.com.
Cory
Old July 20th, 2004, 21:35
mike86xj mike86xj is offline
check here
http://www.lunghd.com/Tech_Articles/...udget_Lift.htm
I am using this lift and clearing 33x12.50's with lots of trimming/hammering and no flares right now
as for the gearing go to the cheapest wrecker around and grab front and rear gearset's from a 4cyl xj, (most are 4.10's)
also front shocks from a stock yj are good for about a 4" lift on a xj
Old July 20th, 2004, 23:45
Big Red's Avatar
Big Red Big Red is offline
The ebay re kit does look good, but it is for a mj and will work on an xj, but there are no spring packs in this auction. The kit still sells for $1,200 from re. You could get the kit for $500 or so and then do 2" block, shackes, and maybe a aal in the back to get your lift with your stock pack or get dakota packs and blocks to get your 5.5" or so. The Rough Country kit is a good deal on ebay and it is always being sold there for months/years because I have seen it that long, but I ended up getting a 91' xj nicely set up with 7" lift so I didn't get it from them. Don't bid too much because there will be other kits coming up every few days so get a good deal and don't stress if you get outbid. For 33's you will need 4.5" lift and some trimming of your fenders. Look at cheapxj.com for some tips, this guys has some really good ideas he has used a tight budget. So for $1K budget which is really low, you should be able to get your tires, rims, drop t-case spacers & 4-1/2 lift to clear your 33 MTRs. This will look really good. MTRs are great tires, I have 35's and they do awesome in the rock trails here in Nor Cal.
4 wheel drive release question?? Lewis OEM Tech Discussion 12 May 14th, 2006 09:27
Help build a Chopsaw stand JnJ Non-Tech / Off Topic 4 December 9th, 2003 17:28
Steering stop question? red87cherokee Modified Tech Discussion 1 December 6th, 2003 08:58
Headers Question Garthbmn7 Modified Tech Discussion 1 December 6th, 2003 06:40
CHeap on board air..... RINGKONG Tow Rigs and Trailers 25 October 6th, 2003 22:56
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
