Old July 6th, 2004, 21:22
joecool's Avatar
joecool joecool is offline
Cool Front Driveshaft Questions
I have done some searching, but haven't found all the answers I'm looking for. I have a 94 with 103k miles, about 3" of lift, 1" tc drop. Anyway, after coming back from a jamboree I noticed a squeaking noise coming from my front end. I had it checked out and they said my front drive shaft was going bad, but I didn't have time to let them fix it that day anyway. So what I am getting at here is should I buy an aftermarket one or is the OEM one fine? If I should get an aftermarket one, what make and do I need to change the length or anything like that? Should I change it myself (I have only basic mechanic knowledge)? Lastly, what would have caused it to start going bad? That way I can prevent it from happening again (just old and worn out?) Thanks in advance for reading all this and any information you have. Hope this all makes sense.
Old July 6th, 2004, 21:23
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Re: Front Driveshaft Questions
How is it going bad? is it the joint? if so it can be rebuilt by a driveshaft shop. Is it hte ujoints? if so, you should be able to replace them yourself. Good test would be to take the driveshaft off and drive without it and see what happens (as in is there a noise or is it gone)
Old July 6th, 2004, 21:35
joecool's Avatar
Oh yeah it is a double cardan if that changes things. anyway, I took it into tire kingdom, because i thought it was the brakes at first. They didnt tell me what was exactly wrong. they just said it was going bad, and told me it would be about $300 to replace. I was going to try removing the shaft, but i havent had time, hopefully tomorrow. I will let you know the results. Thanks again.
Old July 6th, 2004, 21:50
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
If it's just an angry squeaking; the centering joint on the double-cardan is probably dry. It can be rebuilt for far less than the $300 they want to do it for; most driveshaft shops or NAPA should have the Spicer part you need.
Old July 7th, 2004, 09:23
Bender Bender is offline
Years ago those couble cardan centering balls were greaseable but for some reason they don't seem to be anymore. You can take yours apart and check the needle bearings in the centering ball for wear...if they're o.k. you can regrease and re-install it. As a precaution it is a good idea to disassemble those non-greaseable centering balls and relube them yearly....or more often if you dunk your rig in water regularly.
Old July 9th, 2004, 20:09
Jeff-97XJ's Avatar
Jeff-97XJ Jeff-97XJ is offline
I just had the front drive shaft of my 97 rebuilt. I had 182,000 miles on it.
3 U-Joints, and 1 ball, and then a re-balance. $125.00.
It is easy to take off and reinstall and that would save you some cash.
Bring it to a reputable drive shaft place and let them look at it and tell you what you need.
Hope this helps-
Jeff-97XJ
Old July 9th, 2004, 20:31
85cherokee's Avatar
85cherokee 85cherokee is offline
NAXJA Member #970
I'm curious about this also. I have the crappy "standard duty" front shaft with the unservicable boot, and since the lift, with front engaged it sounds like I am chewing needle bearings up.
Does anyone know if the "heavy duty" front shaft is a direct swap? I can not tell from the pics, I even have factory manuals which clear nothing up about this swap.
Old July 9th, 2004, 22:25
mike86xj mike86xj is offline
do you have the stick in a can front driveshaft?
if so yes they are swapable but you have to watch the length there's a short one and a long one.
auto or standard? what engine?
Old July 22nd, 2004, 22:24
85cherokee's Avatar
NAXJA Member #970
yes! excellent analogy...stick-in-a-can, sounds like it's spitting needle bearings. would love to go to the double-cardan, but don't know if it is a direct swap. it is 2.5L, 904 auto, NP207
Last edited by 85cherokee; July 22nd, 2004 at 22:27. Reason: missed part of question
Rattle can (paint) questions daveleau Paint and Bodywork forum 19 September 26th, 2005 01:59
Weird popping sounds up front Fonzie14 Modified Tech Discussion 3 December 9th, 2003 14:43
double cardon u-joint removal front driveshaft tony597fitter OEM Tech Discussion 12 September 5th, 2003 12:31
Front Dana 44 compatability questions.. MDMIKE Modified Tech Discussion 1 August 28th, 2003 12:16
Front winch bumper started and questions for fabricators BUCKYXJ Modified Tech Discussion 5 June 30th, 2003 14:22
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
