Old April 20th, 2004, 07:26
copperhead's Avatar
copperhead copperhead is offline
NAXJA Member #984
hydraulic clutch lines
Hi all,
Has anyone replaced the hydraulic lines for their clutch. My hard lines are pretty corroded and need to be replaced. The loop with bleeder is the worst. I have never tried this and am debating taking it to a shop to have it done. If it is pretty straight forward though, I'll try it.
Thanks,
Copperhead
1987 Laredo 4.0
Old April 20th, 2004, 11:50
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: hydraulic clutch lines
I did it on an '88 last autumn. The only nuisancy part was getting the hard line out where it crosses from the master cylinder under the lip in the firewall. Tight fit, but I got the old one out and the new one in with a bit of fussing.
Fuzzy memory tells me that something was being a PITA and I did the removal with the aid of a large bolt cutter to make it into two pieces, but I can't remember just what it was that caused me to think that was a good idea. Probably the bit about getting the hard line out from under that lip. New one went in very nicely.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old April 20th, 2004, 16:52
BrokenXJ BrokenXJ is offline
If the clutch master cyllinder is original, you should replace this at the same time. When I replaced my clutch, and lost the prime on the spent cylinder I had to replace it.
Old April 20th, 2004, 21:20
copperhead's Avatar
NAXJA Member #984
Thanks,
I'll give it a try. As far as I can tell, the clutch master cylinder is original. The original owner is a friend, and he doesn't remember having it replaced.
Copperhead
-1987 Laredo 4.0, 2door, Stock
Old April 21st, 2004, 22:36
truckeejeeper's Avatar
truckeejeeper truckeejeeper is offline
Please let everyone know how this turns out, and what/where you bought the parts. I have similar problems...thanks! - TJ
Hydraulic Clutch Question rattler43 OEM Tech Discussion 17 April 21st, 2004 09:02
Problems with clutch, hydraulic system related? SyCo OEM Tech Discussion 15 March 6th, 2004 20:52
Clutch help! truckeejeeper OEM Tech Discussion 16 December 16th, 2003 05:41
Adjusting hydraulic clutch ?? Anthropy OEM Tech Discussion 3 August 10th, 2003 00:17
Vacuum problem? Kejtar OEM Tech Discussion 13 August 1st, 2003 17:54
