Old February 22nd, 2004, 11:34
BrokenXJ BrokenXJ is offline
Alternator not changing battery?
OK, we are 1/2 mile into a snow run when old Broken dies because there is no power to run the fuel pump. The alternator light didn't come on, but other people on the run were convinced it was the alternater. So out comes the new alternater(spare) and we change it in the snow. Did not help, so we charged the battery for about 1/2 hour, and made a mad dash back to the tow rig.
Now I'm really confused about this electrical system? If anybody has any ideas, I'd be glad to hear them. I have a volt meter, to test connections but don't really know where to start?
BTW: 88' XJ 4 Liter
Old February 22nd, 2004, 11:48
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Start by testing battery voltage between the two terminals with the engine NOT running. Should be about 12.6 volts, I believe.
Then start the engine, let it run for a minute or so, and test the battery across the terminals again, with the engine running. If the alternator is producing charging current, it should read 13.8 volts.
If it reads 13.8 volts, leave the engine idline and turn on the headlights, then test again. If it's still not up around 13-1/2 volts, the alternator can't handle the load of the lights.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old February 23rd, 2004, 21:01
CheapXJ's Avatar
CheapXJ CheapXJ is offline
Re: Alternator not changing battery?
fuselink between alt and battery?
check for continuity between alt+ and bat+
