Old April 8th, 2003, 21:25
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Rusty's Cross Member and 1" drop cross member
OK... so the big question is is the 1" drop one less sturdy (sacrificing some brace or stiffener) because it is supposedly same clearance as the other one.
Also for time being can I attach that stock t-case skid to it for now? (I am sooooo broke at the moment and my tax refund $$ has to go to something else )
Kejtar
Old April 8th, 2003, 21:51
ChuckD's Avatar
ChuckD ChuckD is offline
If your so broke just do a TC case drop, if you already didn't have one. At the most it would cost you about $25 for a piece of 1x2 rect tubing and some bolts. Use Gojeep's instructions, I hope you can convert metric to imperial.
Later when you have the money get the SYE.
Old April 8th, 2003, 21:56
Kejtar's Avatar
PostMaster General
I have the drop, that's not the issue, but I am considering going without the drop for a while if I can use the crossmember with the 1" lowering from the get go (so for time being I get best of both worlds: drop and keep clearance)
Kejtar
P.S. I was born and raised on metric... I still have trouble with imperial every so often.....
Old April 8th, 2003, 22:12
ChuckD's Avatar
Good point, I guess you could always resell the cross member.
Old April 8th, 2003, 22:13
Kejtar's Avatar
PostMaster General
yup
Old April 8th, 2003, 22:19
bbaker80's Avatar
bbaker80 bbaker80 is offline
I'm using Rusty's 1" drop cross member. My guess is it's 1/4" steel, and welded into a box, so I doubt you're going to hurt it. Mine has been on for about a year and a half now, with 2 trips to Paragon and some local wheeling, and other than a bunch of scratches, it still looks new. I'd say go for it, you won't be sorry you did.
Old April 9th, 2003, 00:36
Safari Ary's Avatar
Safari Ary Safari Ary is offline
Kej, how pressed are you for time?? I was going to work on a flat x-member this weekend for myself. I could probably duplicate it fairly cheaply and send you one. You could just lower it so that you are at or below the stock height(a flat x-member raises the tranny 5/8"(a little more than 1cm )). Let me know if you're interested in hearing more. Peace
Ary
Old April 9th, 2003, 02:31
XJoachim's Avatar
XJoachim XJoachim is offline
You cannot fit the Mopar t-case skid to the 1" drop crossmember. The t-case hangs too low to attach the skid to the crossmember. Rustys long arm kit comes with the built in 1" drop and im going to install a 1" raised tranny mount to get the t-case up where it belongs. My advice ist: Don't do it, if clearance is important for you go with the SYE an then loose the 1" drop.
Old April 9th, 2003, 10:23
Ronbo's Avatar
Ronbo Ronbo is offline
My factory transfercase skid bolts up without any problem to Rustys' drop crossmember. The x-fer case doesn't come close to hitting the skid. Weird.
Old April 9th, 2003, 15:03
Kejtar's Avatar
PostMaster General
to those of you that installed the crossmember: the tranny mount just matches over? I hope
Old April 9th, 2003, 15:59
Ronbo's Avatar
Yes, same mount.
Old April 9th, 2003, 19:17
Georgia Mike's Avatar
Georgia Mike Georgia Mike is offline
Top notch piece I've got the 1" drop version,x-case skid,and engine skid. It was expensive to buy it all,but I've never for a second regretted it!
Old April 13th, 2003, 21:44
juicexj24 juicexj24 is offline
Spacer
I Rusty's Cross member with the 1" drop. Even Rusty's when I tried to put Rusty's Skid Plate back on I needed to use some spacers between the skid and the crossmember to clear the x-case. Works great and looks fine.
Old April 13th, 2003, 22:50
Kejtar's Avatar
PostMaster General
hmmm... I didn't seem to have that problem... I just had to use a BFH to shape it better LOL. In any case I will be looking into better alternatives though for the skid
Rusty's Crossmember with 1" drop Getcha_Sum For Sale: Private Party Only. XJ ITEMS ONLY 9 December 8th, 2003 21:40
TC 1" drop, is that the limit? GrimGrimDutch Modified Tech Discussion 7 October 31st, 2003 02:49
1" drop cross member rread@nti.net For Sale: Private Party Only. XJ ITEMS ONLY 0 August 15th, 2003 05:44
