Old February 1st, 2004, 12:01
dogtired's Avatar
dogtired dogtired is offline
disconnect battery when changing oil?
somehow I missed something in MadXJ's page about synthetic oil filter size comparisons. He mentioned about shorting the starter solenoid when changing the huge Mobil1 301 oil filter... can anyone shed any light on that? How can an oil filter short out something else when the filter itself is not electrical in someway? I just changed my Mobil1 filter and it didn't short... or maybe I am just lucky.
here is the link, (the statement near the top of the page is highlighted in red): http://www.madxj.com/MADXJ/technical...Conversion.htm
Old February 1st, 2004, 12:25
Lou's Avatar
Lou Lou is offline
I have not Confirmed, or I used a BAD email Addy
....when you drop your wrench on it....the filter(adapter/mount) is just above the starter.
Old February 1st, 2004, 12:49
Dano's Avatar
Dano Dano is offline
NAXJA Member #1269
if you instal the filter from the bottom you might get a shock. like playing operation on your jeep.
Old February 1st, 2004, 21:14
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Yes it can happen.The shop where I helped out this summer had a 5 spd run into the pit when the filter can shorted the starter.I wasn,t there at the time---
The terminals on the starter are suppota have a rubber cover but age and repair will remove them.
Be careful out there------
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old February 1st, 2004, 22:18
dogtired's Avatar
Wayne
ok thanks, so to reiterate... never put wrenches or anything metallic on battery posts and two... put some kind of non conductive layer between the starter and oil filter or just be extra careful not to touch starter with the bigger oil filter.
please correct me if I am wrong or anything else I might have missed. I like the Mobil1 301 filter for bigger heat dissapation and extra fluid capacity and filtering capability.
Old February 1st, 2004, 22:41
Wiley Coyote's Avatar
Wiley Coyote Wiley Coyote is offline
I have a í91 with the 204-style oil filter in the vertical position. Iíve never tried it, but it looks like there is plenty of room to put in the larger 301-style filter. I can easily reach in and touch the top of the filter with no obstructions. I understand converting to the standard thread, but why would you want a horizontal mounted filter? There is much more room with the vertical mount.
Old February 2nd, 2004, 05:33
dogtired's Avatar
mine came as horizontal... stock. I wish it was vertical, so I don't spill oil when I drain it. I suppose it gives us more clearance when we go offroadin
Old February 2nd, 2004, 08:27
Jeremyvnc's Avatar
Jeremyvnc Jeremyvnc is offline
other than more oil capacity and usage, what does a larger oil filter do?
Old February 2nd, 2004, 08:58
dogtired's Avatar
larger surface area for filtration and cooling kinda like an air filter... bigger surface area for more filtration and breathes easier
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
