Old January 29th, 2004, 19:01
mark91xjbeef's Avatar
mark91xjbeef mark91xjbeef is offline
alternator upgrade
i finally upgraded my alternator. i used a 120 amp model from a 97 grand cherokee 5.2l. the mounting dimensions are the same on the two the case on the 120 amp model is just a little bigger. i only had to do about 5 to 10 minutes of grinding on the cast bracket. also the support brace needed a 1/4 inch taken off to fit back on.i still need to download the pics and i will post them. the best part is i got it from kragen and it has a lifetime warranty. this is where i got the idea.
Old March 16th, 2011, 19:26
kensommers kensommers is offline
Re: alternator upgrade
Old March 18th, 2011, 06:31
j33pownr's Avatar
j33pownr j33pownr is offline
7 Years Later ....
Did you need somthing ?
