Old December 31st, 2003, 18:25
jjvande's Avatar
jjvande jjvande is offline
5" lift and need new brake lines..
so my stock front brake lines finally gave out after all the stretching...I went to NAPA to look at the 95' YJ fronts, and wasnt very satisfied with them as a longer replacement. THe rubber portion of the line was the same length as my stock ones, but the metal tube that connects to the calliper was aobut 3" longer on the YJ ones. This metal tube was bent in a way that i don't see how to mount them to increase slack.
Has anyone used the NAPA lines?
should i get em and bend the metal tube?
who has the best deal on SS lines for teh front?
-Thanks
Old December 31st, 2003, 18:32
96XJCLASSIC's Avatar
96XJCLASSIC 96XJCLASSIC is offline
Re: 5" lift and need new brake lines..
I am at 4.5" of lift and am using 95 YJ lines and they work fine. I didn't need to bend the metal portion at all. A direct replacement. HTH, NICK
Old December 31st, 2003, 18:53
yikes yikes is offline
I have a 1999 with a R E 3 1/2" kit with 1 3/4 frt spacers and 1 1/4 lift rear shackles and the 1995 yj hoses front and rear work fine-i think I bent the metal part on the fronts a little bit- nothing major -just by hand
Old January 1st, 2004, 14:05
jjvande's Avatar
Thanks, i wasn't sure if having that metal tube sticking out there was going to be a problem or not....i'll give em another chance.
-J
