Old December 9th, 2003, 06:16
maineiac maineiac is offline
starter ?
when my jeep is cold and i turn the key i get one click than nothing if i keep letting off the key than turning it after about 25 times it turns over . do i have to replace the starter or just the selanoid ?selanoid 12.00 starter 90.00
Old December 9th, 2003, 06:21
Re: starter ?
oh yea after its warm its fine till it gets cold again ,its an 89 with a 4.0
Old December 9th, 2003, 07:05
90red's Avatar
90red 90red is offline
Re: starter ?
I have a 90 4.0 and my starter just went out. I went ahead and replaced the starter. I dont know if replacing the solenoid will fix it, but it may. My starter would click like yours and the whole time I thought I had an electrical problem. I replaced a bunch of stuff and I still had the same problem. Then one day I go to turn the key and nothing, not even a click. Yeah, its $90, but after I installed mine it would start like a champ. Good luck with your XJ.
90red
Old December 9th, 2003, 09:32
Erik the Red Erik the Red is offline
Re: starter ?
Maineiac,
I hate to suggest spending money when it may not be absolutely necessary, but I recommend that if you need to replace either the starter or the solenoid then you should replace them both at the same time. I figure that if one is going out, the other will shortly follow and you don't want to have to get back underneath a second time.
BUT, since your problem occurs when it's cold out, have you ruled out the possibility of a failing battery?
Erik
88 Comanche
Old December 9th, 2003, 09:38
FatXJ's Avatar
FatXJ FatXJ is offline
Re: starter ?
What you need to check is the starter realy switch. Mine freezes up all the time and I can still start it by powering the solenoid with a screwdriver.
Next time it does it grab a screwdriver and jump the post with the power cable running to it with the small post with the small switch cable running to it. If it starts then its your switch not your starter.
Old December 9th, 2003, 10:54
2xtreme's Avatar
2xtreme 2xtreme is offline
Re: starter ?
I agree starter relay is the most likely culprit.
Michael
Old December 9th, 2003, 19:54
Re: starter ?
ill try that the reason why i didnt think it was that is because of a slight click when it is turned on thanks guys
Old December 9th, 2003, 22:06
8Mud's Avatar
8Mud 8Mud is offline
Re: starter ?
Was having some alternator issues and had to swap out the battery a couple of times (one on the charger, one in the XJ). After about the third swap, had the same symptoms you discribe. Oil/grease on the battery poles, cleaned with brake cleaner, sanded reinstalled, started right up.
When the brushes are going bad or not making good contact in the starter, a sharp rap with a hammer on the back of the starter, is usually good for a couple of more starts.
The starter relay, usually looks fairly corroded inside, never had one fail on an XJ, but have seen many act up on the Dodge (pretty much the same part).
Noticed after cleaning the grounds, where the battery ground, hooks to the dipstick bracket and the motor to the firewall. My alternator charged better and the starter turned over a little faster.
Also had a bolt back out of the starter (believe it was the bottom) starting became a sometimes, thing.
I don't need a new starter, just new brushes scott in NH OEM Tech Discussion 5 December 6th, 2003 12:26
Starter Actuator Arm Removal Pioneer89 OEM Tech Discussion 1 November 2nd, 2003 22:21
Starter question mattk OEM Tech Discussion 3 August 25th, 2003 09:40
Starter only works with hotwiring Mich88XJ OEM Tech Discussion 3 August 21st, 2003 20:47
Starter question? anybody help Joe Sierra Chapter 3 September 19th, 2002 13:06
