Go Back   NAXJA Forums -::- North American XJ Association > Support and Administration Forum > User Support, Questions and Suggestions
User Support, Questions and Suggestions Not Jeep Tech Questions. Forum use related questions or comments only.
Old December 7th, 2003, 14:44
Glenn B's Avatar
Glenn B Glenn B is offline
Admin and Member #69
vB 3 Bugs? Post em here.
Please post any bugs you may come across in this thread.
Include as much detail as is possible; including the exact error message you received, the URL or function you experienced the error at, as well as what hapened after the error: did it continue with the expected action (posted, deleted etc...) or was it a hard failure.
Thanks.
2001 4door XJ. 4.5 inch long arms, 33x12.50-15 Mickey Thompson Baja MTZ's, Superchips Flashpaq, bigger throttle body, AFE cold air intake, Advanced Adapters SYE, and a ton of stuff still to do on this project!
Old December 7th, 2003, 14:45
Glenn B's Avatar
Re: vB 3 Bugs? Post em here.
Bug fixed: Unable to delete single PM.
Old December 7th, 2003, 14:46
Glenn B's Avatar
Bug Fixed: Edit or delete post.
Old December 7th, 2003, 19:49
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
I keep getting script errors when I hit submit reply or submit post.
It's a runtime error line xxx object unexpected.
Old December 10th, 2003, 09:44
Lou's Avatar
Lou Lou is offline
I have not Confirmed, or I used a BAD email Addy
(minor nuisance -- not a real problem)
Infrequently, when scrolling(bar) throught a thread I get a 'trail'(like a mouse trail) of one particular line in the thread -- it repeats down the entire screen --a second or two passes and it's all better.
Didn't happen on the last version of vBulletin.
running Ie v6.0.2800 on XP Pro.
Old December 12th, 2003, 19:58
Lou's Avatar
Lou Lou is offline
Well, I think I found the resolution while I was browsing the 'other' bug thread. I also had the disappearing post issue.
--> Don't use the Classic theme (for now?) it has issues.
Thanks anyway Tim. It was my favorite.
Old December 12th, 2003, 20:06
Glenn B's Avatar
Originally Posted by Lou
Well, I think I found the resolution while I was brousing the 'other' bug thread. I also had the disappearing post issue.
Indeed it has issues. It has been removed. That one is not Tim's fault, he did the Red N Grey theme, not the old one.
It may be back at some point after further work on it.
Old December 14th, 2003, 13:09
Kejtar's Avatar
PostMaster General
OK... question... with the new forum software update, was the zend engine updated as well? If not, what could potentially be slowing down the loading of posts? What happens is that the original transfer is made, but then it goes into opening page and it's stuck there for a while. I thought for a while that it might be my ISP, but the issue seems to be isolated to the forum only... I have also cleaned out my cache and for test purposed browsed through the regular pages on naxja.org and didn;t see any problems with them... so again that makes me wonder about the forums.
Old December 14th, 2003, 13:25
F. F.'s Avatar
F. F. F. F. is offline
RELAX, this is the WEB
Makes you wonder about the forums? Not sure what you infer by that?
No Zend was not changed, and has nothing to do with this aspect.
I suggest you go in to your UserCP and adjust your preferences to find a combination of settings that works for you. You may have the Standard or Enhanced editor enabled. Try using the Basic editor. The more features you have enabled, the more elements have to be loaded.
Also, more information is needed.
Define the time period for: "but then it goes into opening page and it's stuck there for a while"
What theme are you using? And do you see the same behaivior on other themes?
Forum Rules: READ ME
Old December 14th, 2003, 15:22
F. F.'s Avatar
I just moved most of the CSS to cacheable files, and that saves a little download time. A few other features were knocked off.
Not much more fat to trim without people yelling about that. . The biggest perceivable slowdown (though very minor on my end) is eliminated by removing the "quick reply" feature. That is not an acceptable solution.
FWIW, most aspects seem faster to me, while a few seem a *little* slower. Perhaps the script writers will be able to speed up those areas with the next release.
Sooooo. That is where we are.
You may need to do an F5 refresh to use the slimmed down code, in case your machine is cacheing any aspects.
Old December 14th, 2003, 15:59
Kejtar's Avatar
PostMaster General
ok... thanks.. I'll see how it goes
Old December 15th, 2003, 02:14
Arakele's Avatar
Arakele Arakele is offline
NAXJA Member #946
using Mozilla/Netscape this is how the reply box looks, the smilies on the side are cut off
http://xj.no-ip.org/naxjaerror.jpg file was big so i didnt embed it into the post
Old December 15th, 2003, 10:57
F. F.'s Avatar
Yup, I just tried Firebird, and see the same thing.
Problem noted.
Thanks.
Old December 15th, 2003, 19:53
Skorpyo's Avatar
Skorpyo Skorpyo is offline
NAXJA Member #241
What happened to the gradients? Noticed that all of the forum styles are lacking the gradient images that give them that extra special smooth and sleek look....eh?
Skorpyo
Old December 15th, 2003, 20:40
Glenn B's Avatar
Skorpyo
Hmm. now that ya mention it, I see it. The only change with the CSS was moving them from the scripts in to a cache-able file in the hopes that is may be quicker for those complaining it is slow.
Hit me back channel if you do not see where they are, or if that setting wont work.
Rate This Thread:
user names to the left of the post instead of the top? dennisuello User Support, Questions and Suggestions 1 December 5th, 2003 20:58
Post count & tag above avatar ThePhantum User Support, Questions and Suggestions 3 November 17th, 2003 21:35
Is anyone bringing a computer to this event to post for those that aren't coming? TRNDRVR 2003 20th Anniversary Celebration! Moab, Utah 23 September 28th, 2003 20:28
ABS, or no (first post) 3312DC OEM Tech Discussion 3 June 7th, 2003 23:33
