Old November 19th, 2003, 21:33
Andy Steiner's Avatar
Andy Steiner Andy Steiner is offline
Gone but not forgotten...
Spare Brake Lines
I've been carrying a spare front and a spare rear brake line since I got my Heep. Now that is sufficiently lifted, those are too short. I've replaced the rear brake line with a Skyjacker stainless steel braided line, but I still want to carry spares, cause ya never know. My mechanic got me the spare hoses originally and told me that if I can tell him the Napa part numbers that I need, he can return the hoses that I haven't used for credit and get the longer ones I need.
Questions:
1. I hear that YJ brake lines are longer and will work. True?
2. Any particular year YJ?
3. Are the front brake lines different and should I carry one of each?
4. Anybody know what the correct Napa part numbers are?
Thanks people!
[SIZE=3][FONT=Comic Sans MS][COLOR=Magenta]Andy [/COLOR][/FONT][/SIZE]
Some people try to turn back their odometers.
Not me! I want people to know why I look this way. I've traveled a long way and some of the roads weren't paved.
Old November 19th, 2003, 21:48
Ralph's Avatar
Ralph Ralph is offline
NAXJA Member #149
Questions:
1. For the size lift you discribe in your sig, a YJ rear line will work.
2. I told the guy at NAPA that I wanted one for a '95 model YJ.
3. You don't need front ones. Your XJ brake lines will work for the size lift you have. You can gently straighten the bend in the hard line and relocate the attachment to the fender well lower. I'm still using stock length hoses with a 4.5" lift.
4. Ask the guy at the NAPA store. He's got all the numbers in some books he keeps behind the counter.
RR3
Old November 20th, 2003, 08:17
Handlebars Handlebars is offline
NAXJA Member #135
Here's what the YJ front brake lines look like:
I'd suggest putting them in, relocating the hard line as low as it will go to maximize legnth. Don't worry about carrying a spare, the rubber hoses are more resiliant than the stainless steel ones and a spare is as close as the nearest auto parts store. Tell them you need all three hoses for a non-ABS '95 YJ.
Is this enough droop for 'ya?
Old November 20th, 2003, 11:55
LOCKED UP's Avatar
LOCKED UP LOCKED UP is offline
I'm running lines from a 92 cheby .... cheap & they are about 24" length total....
Old November 20th, 2003, 13:03
sarvermr's Avatar
sarvermr sarvermr is offline
a 92 chevy what? Astro? Blazer? Camaro? Caprice? Cavalier?Corsica? Corvette?
2wd? 4wd? front? rear? do they bolt to the xj hard lines? calipers? come on man, help us out a little!
thanks,
matthew
Spare tire carrier dana44 OEM Tech Discussion 8 September 30th, 2005 15:35
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 15:51
leaky RE SS brake lines FYR WOOD Modified Tech Discussion 5 November 5th, 2003 08:10
using TJ rear brake lines as extensions BLUTO Modified Tech Discussion 2 July 31st, 2003 23:50
Adapting extended SS brake lines. KarmirXJ Modified Tech Discussion 2 June 25th, 2003 08:44
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
