Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old November 17th, 2003, 18:57
Xtreme XJ's Avatar
Xtreme XJ Xtreme XJ is offline
NAXJA Member #1138
MJ bed trailer ideas..
Who has made a trailer out of the MJ bed? Did you make it a utility trailer or a camping trailer? Did you use the bed only or use the exsisting frame and extend the tongue? Any magic # for a tongue length?
I'm toying with the idea of building one.
See Ya!
Curt (aka Xtreme XJ)
Old November 17th, 2003, 19:01
rockwerks's Avatar
rockwerks rockwerks is offline
In AZ you can no longer register a trailer that has been made out of a truck bed, adn I believe CA is the same, I was gonna make a wheelin trailer but the state shot me down
Old November 17th, 2003, 19:05
Hunter-Lynchburg,Va Hunter-Lynchburg,Va is offline
cant you just put the bed on your own frame and get a new VIN from DMV and register it as a homemade trailer? or can you not have homemade trailers period?
Hunter
Old November 17th, 2003, 19:40
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Lawn Cher' has one made by chopping off a wrecked MJ behind the cab and adding a 'Y' to the front of the frame rails.
Fore Wheeler made one using his own subframe.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old November 17th, 2003, 20:05
rockwerks's Avatar
these type are no longer legal in AZ, ones that are already been made aera granfathered but no new ones
trailers can be homebuilt tough, I guess you could made a flatbed frame, get it registered take it home and put the bed on it
Old November 18th, 2003, 11:35
Xtreme XJ's Avatar
NAXJA Member #1138
Ca. is O.K.
Well I called Ca. DMV (what a chore the day after our newly elected Gov. repealed the 300% car reg. fees.) this morning & they said the trailer is fine to build and register as long as I have documentation (the receipt from the boneyard) and bring it and all other paper work to the DMV when I go to register it.
So thats one fire stomped out....
Thanks !
Curt (Xtreme XJ)
Old November 18th, 2003, 12:47
Fore Wheeler's Avatar
Fore Wheeler Fore Wheeler is offline
Past MWC President
I know that Eagle and XtremeXJ both have this pic, but for the rest of you, this is what I've done...
I like the idea and clean look of the built frame, and it's easy. Toung length I determined by figureing what distance I needed to jack-knife the trailer and have my bumper hit the toung instead of the trailer box hitting my Jeep. Right or wrong, that's how I did it. I also built it to handle 38" tires with a 5 on 5.5" bolt pattern to match my XJ axles, this way I've always have two more spares.
member #285
My build thread: Out of Misery II
Old November 18th, 2003, 13:46
MJlogan MJlogan is offline
You want a mj bed? If you dont mind a little bodywork, i might have a complete one availibe pretty soon....
Old November 18th, 2003, 20:00
jeepmj_tj jeepmj_tj is offline
i had more pics of this guys trailer, but i dont know what happend to them and the web where i got them doesnt work any more...oh well.
Old November 19th, 2003, 08:32
partsbill partsbill is offline
Do you have a relatively good tailgate on that instead of the whole bed/
Bill
Old November 19th, 2003, 09:03
Originally posted by jeepmj_tj
i had more pics of this guys trailer, but i dont know what happend to them and the web where i got them doesnt work any more...oh well. [/B]
lemme try it again
Old November 19th, 2003, 13:24
Bill
Yeah the tailgate is in decent shape. I'll post it on the for sale forum when i get my flatbed done- might be a while though...
Old November 19th, 2003, 15:20
8Mud's Avatar
8Mud 8Mud is offline
Just a thought, but I have a trash hauler, with a single trailing arm(each side), coil, independant suspension. I took the whole rear sub frame, off of, a front wheel drive Van. Any load from empty, to overloaded, it pulls better than any leaf spring type trailer, Ive ever tried. Ive layed tools in the back and had them still be there, when I got home (driving empty) and have run loads around a ton. Works really well on the interstate. Bonus is it has a 4 1/2 inch bolt pattern.
The frame is a big T, with the cross of the T being the mount for the sub frame and suspension. Frame could be a + , for extra strength. A few ribs and your finished.
My bed is a sheet of sealed (polyester coated) 3/4 inch plywood. Might rot somewhere sometime, mine is over ten years old. Dont under estimate plywood, a few bolts (large washers) and a sturdy frame, make a really durable platform.
As a side note, Ive used plywood (12 ply) for skid plates, actually works better than steel or aluminum. Wont bend, wont dent, has a really good memory (springs back to where it was), easy to replace. Used it for a sub frame on VW Buggies.
Old November 20th, 2003, 11:19
Jeff 98XJ WI Jeff 98XJ WI is offline
If you can access the madxj yahoogroups, I have a number of pictures of my long bed MJ trailer in the files section under Jeffs Jeep mods and then in MJ trailer. I purchased the back of a 86 MJ which had been chopped directly behind the cab. I trimmed the frame rails even with the front of the bed with a little asthetic angle after 3 inches down. I built a real heavy tongue with 3x3x.25 steel and 4x2x.25 steel tubing to give the trailer enough tongue weight. The 3x3 slides into the MJ frame about 1.5' and is through bolted with three bolts per side. The rear most bolts also go through a C channel crossmember with tabs welded to the end that the bolts go through. A long tongue made of the 2x4 tubing is welded to the center of the C channel crossmember and extends out to where a bolt on hitch coupler sits. The 3x3 frame pieces come out a few inches from the frame rails and then angle in to the 2x4 tongue. I also added a piece of 2x4x1/8 that goes across the front of the bed and fits into the the A-frame to make kind of a bumper for the front of the bed. So far I am using the stock '86 rear axle, but plan to make a new axle using full sized chevy front spindles/hubs/wheel bearings. THat way I'll have individual wheel bearings and a matching bolt pattern for the 6 on 5.5 axles on my XJ. Jeff
MJ bed gr8tires OEM Tech Discussion 7 July 16th, 2004 11:59
My rig and trailer for sale :( XJ4PINOY For Sale: Private Party Only. XJ ITEMS ONLY 10 January 4th, 2004 07:46
MJ ride height? Am I sagging? Cheropair OEM Tech Discussion 2 December 9th, 2003 08:45
A chance at a MJ triple 4 Modified Tech Discussion 5 December 9th, 2003 03:58
MJ bed sizes PA Highlander OEM Tech Discussion 2 November 8th, 2003 13:04
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
