Old November 4th, 2003, 16:40
FYR WOOD FYR WOOD is offline
Question leaky RE SS brake lines
Has anyone had a problem with the braided brake lines from RE? My fronts are leaking where the hard line threads into the new line. As far as I can tell, the leak appears to be coming from the threads, not from between the hard line and the flare nut. Is it a bad idea to use teflon tape on brake lines? I've never had a problem with brake lines before, and my 5.5 kit went on so well.... No problems at all. Just this. Any solutions? Thanks.
Old November 4th, 2003, 17:08
RCP Phx RCP Phx is offline
Well theres really only a couple things that could be wrong!
1-the fitting is loose
2-the fitting on the flex line is "nicked"
3-the flare on the hard line is "nicked"
4-the fittings are not properly "matched"
the threads do not do any "sealing"
Old November 4th, 2003, 18:38
TOZOVR's Avatar
TOZOVR TOZOVR is offline
NAXJA Member #713
Blast it with brake cleaner and use a nice flare nut wrench to tighten it (hold the upper line with another wrench)
Old November 4th, 2003, 18:40
did that...still leakin...
Old November 5th, 2003, 06:00
PAXJRUNNER's Avatar
PAXJRUNNER PAXJRUNNER is offline
might need to just go ahead and buy a "double flare" kit and
do new connections and fittings.
Old November 5th, 2003, 08:10
bbaker80's Avatar
bbaker80 bbaker80 is offline
I found an inexpensive double flare kit at Sears that has worked pretty well for me so far. I used it to replace the fittings on the hard lines on my rear axle, as well as replace the fittings on the front when I installed my RE SS lines this summer. Seemed to work pretty well, and was only around $30.00 IRRC.
Bryan
Brake Noise Urban Redneck Modified Tech Discussion 4 December 6th, 2003 21:18
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 15:51
Spare Brake Lines Andy Steiner Modified Tech Discussion 4 November 20th, 2003 13:03
using TJ rear brake lines as extensions BLUTO Modified Tech Discussion 2 July 31st, 2003 23:50
Adapting extended SS brake lines. KarmirXJ Modified Tech Discussion 2 June 25th, 2003 08:44
