Old December 8th, 2017, 22:21
cstew00 cstew00 is offline
Locker and braking
Hey guys, I have a question.
I have a lunchbox (not sure what brand, been in there for a while and haven't had an ounce of trouble out of it) locker in the front and rear of my XJ (stock dana in the front and ford 8.8 rear, both 4.10's)
Today in the snow when driving in 2wd if one of my front tires were to lose traction, it would try to engage the locker.. I was driving for at least an hour before it started doing it...
Can someone explain to me why this is happening? I am trying to wrap my head around the mechanical operation of this.. If the 4wd is not engaged, then it shouldn't be pushing out the plates to lock.. Possible that the springs are broken in the locker?
I am at a loss.. Any explanation/help is appreciated
Old December 8th, 2017, 22:37
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Re: Locker and braking
It's in differential mode: not locking up, but ratcheting.
Old December 8th, 2017, 23:06
clydefrog's Avatar
clydefrog clydefrog is offline
How do you know the front is loosing traction? Understeer?
The front auto locker (assuming that's what you have) should work regardless of being engaged in 4wd or not. You speak of it "pushing" out the plates but do not know what is actually installed. I would start by seeing what is actually in there then maybe we could give an explanation.
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old December 9th, 2017, 07:38
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Originally Posted by cstew00 View Post
.... in the snow when driving in 2wd if one of my front tires were to lose traction, it would try to engage the locker...
This is a common behavior of Lunchbox type lockers. Mine does the same thing. I would suppose it is a symptom of some usage wear, and perhaps the need for new locker springs and pins. The locker did not do this when newer.
Several of the members of my local Minneapolis 4x4 club remove their front locker in the fall, and re-install it in the spring, because of this behavior.
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 9th, 2017, 19:17
Thanks for that info Tim. I had a feeling that it was the locker "grabbing".. The first time that it happened I thought one of the bolts came out of the caliper and wedged in my wheel it was so violent..
Old December 9th, 2017, 20:52
The locker does this all the time, front and rear.
The "Automatic locker" has 2 modes, locked and differential.
Then torque is applied, the center pin in the carrier rotates and presses the middle drives into the axle side drivers.
When no torque is applied the tension on the center drivers are released and the space between the inner and outer driver increases. In this state,
If one wheel turns faster then the other, like when you tun a corner the drivers will slip past each other on the faster wheel.
Now when you brake in 2wd and one wheel stops because there is no traction, and the other continues at speed. Your front !ocker is in differential mode and allows the faster wheel to spin independent of the other wheel.
You dont notice it as much in the rear, especially with an automatic.
If you had a Manual you would expect torque steer under when jumping on and off the gas while shifting because of the locker locking and unlocking.
Like Tim said, common, but not because it's worn, but because it's meant to work that way.
If you were to have installed these as new, one of the checks is to hold one wheel still and to make sure the other side can break free and ratchet.
braking Gunter Colorado Chapter 8 April 20th, 2013 23:22
need better braking! XJ longhouse Modified Tech Discussion 9 December 12th, 2011 12:48
60-0 braking? f-a-t-b-o-y OEM Tech Discussion 23 January 19th, 2007 06:48
Better Braking BobCSmith Modified Tech Discussion 12 March 26th, 2004 14:19
almost no braking cjmatt OEM Tech Discussion 7 March 12th, 2004 07:59
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
