Old June 24th, 2014, 12:31
diesel_guy86 diesel_guy86 is offline
1986 diesel XJ
Bought a 1986 diesel xj for a decent price awhile ago. Started doing research and there's just not much about them. My question is, how rare is this thing? I've sent Chrysler the Vin and they say it comes up invalid? Diesels are my thing so I'm not afraid of that and I've found sources for all the parts I needed. Don't know if its worth mentioning, but it has a 5 speedmanual, 2 door with vented rear windows, has a/c, cruise control, and keyless entry. Any help would be greatly appreciated! Thanks- Joe
Old June 24th, 2014, 15:11
joejeep92 joejeep92 is offline
Re: 1986 diesel XJ
Not rare at all...in fact I'll be up with a trailer tomorrow just to take it off your hands . They are farely rare atleast in my part of the country. Seems like Canada got quite a few. Kinda neat but not a lot of power from what I hear. And again...I will buy it haha
Old June 24th, 2014, 23:07
8Mud's Avatar
8Mud 8Mud is offline
Re: 1986 diesel XJ
They were really common here (Germany). but had a lot of head gasket failures. After the first two or three head gaskets people dumped them.
I was talking to a guy in the Czech Republic who has a few, he says the key to longevity is to put in a timer and have an electric fan run for awhile after shutdown. He says most of the head gasket damage happens after shutdown and hot spots form in the motor.
Old June 25th, 2014, 07:11
Re: 1986 diesel XJ
On my way home with it, I had a guy offer me 3 times what I paid for it. Obviously if I had bought it to make money on it I would have sold it then and there, but I have a soft spot for "different" vehicles.
I'm believing what your saying on the hot spots, cylinders 1 and 3 have cracked liners. Already have 2 new ones waiting for me to get to them. Called ARP and had them make me a stud kit for it to get rid of the torque to yield bolts. The studs should keep everything a whole lot more secure. I'll take your advice and install an electric fan. For anyone who doesn't know these engines, there all aluminum, only steel in the engine is the crank, rods, and liners.
Old June 26th, 2014, 19:40
floyd floyd is offline
Re: 1986 diesel XJ
Pics would be cool!
Old June 26th, 2014, 22:02
djgrayxj djgrayxj is offline
Re: 1986 diesel XJ
Note from DJ
I found this information with a Google search
1986 2.1L Turbo Diesel XJ in Idaho!
http://www.cherokeeforum.com/f8/1986...-idaho-155662/
When was the last time you saw a Factory Diesel XJ/MJ
http://www.jeepforum.com/forum/f177/...xj-mj-1392821/
1986 diesel XJ on You Tube
http://www.youtube.com/watch?v=aaJRlYtzupc
1986 Jeep Comanche 2.1 Turbo diesel, 4X4 You Tube
http://www.youtube.com/watch?v=oUMqQODxNSE
Items found similar to "1986 jeep Cherokee diesel 5 speed" ebay link
http://www.ebay.com/sch/sis.html?_nk...d=300602820433
Old June 27th, 2014, 19:31
Re: 1986 diesel XJ
Already seen all those. I know the diesel was a rare(er) option, but how rare are 2 doors, vented windows, and keyless entry? Are there any records of production numbers?
Old June 27th, 2014, 22:06
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Re: 1986 diesel XJ
I wasn't aware of the fact that keyless entry was even an option in '86!
A word of advice, keep an eye on the clutch master/fuse panel area. The former enjoys leaking onto the latter and causing all kinds of electrical gremlins. (I still need to source out fuse block terminals)
I've also heard the pugeot trans is also a weak link.
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old June 28th, 2014, 11:06
Re: 1986 diesel XJ
Me either, but in the owners manual the page that the dealer is suppose to write all the info on (date purchased, Vin number, purchaser etc) it has a blank for the keyless entry I'd number, and its filled out.
Old June 29th, 2014, 10:16
four_shot's Avatar
How 'bout it Gonzo
Re: 1986 diesel XJ
did you get the keyfobs. Thats the important part...lol!
4shot
Old June 30th, 2014, 07:54
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: 1986 diesel XJ
At this point, even if you have the fobs they're probably useless - the circuit board itself in my '92's OEM fob was disintegrating when I bought the truck in 1997.
If this has the IR-based system (like a TV remote), you can get new remotes from Piland Electronics (www.thejeep.com/piland.html). All you need to do is pull the recieiver board off the headliner and find the 5-digit number tag on the circuit board, then call Piland to get hooked up.
Until I swapped in the keyless module from a 1995 Concorde into mine, I ran a Piland remote for years, and it never let me down.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old July 3rd, 2014, 17:33
Re: 1986 diesel XJ
Is the circuit board receiver mounted on the headliner, right above the rear view mirror? Cuz that's where mine is, that site says 88-92, but mine is an 86.
Old July 4th, 2014, 22:39
four_shot's Avatar
How 'bout it Gonzo
Re: 1986 diesel XJ
If its a little black ball looking thing hanging down like a security camera at a casino, then yes.
4shot
Old July 12th, 2014, 03:20
DieselPioneer DieselPioneer is offline
Re: 1986 diesel XJ
I have 2 XJs with the 2.1L diesel, an 85 and an 86. The 86 is a parts vehicle. Both however, have the AX5 transmission. I rebuilt the one in my 85. If your transmission is working I would suggest not rebuilding it it no matter how many miles are on it. From what I could tell it is a well designed transmission and should go a long long time behind the diesel..
I have also rebuilt the engine in my 85 and got to know the beast quite well. The head gasket has been an issue as 8Mud has said. Mine as well. With a flow-through design expansion tank, it communicated to me that even the manufacturer knew there were head gasket problems. The flow through design helped to scavenge combustion gasses that got past the head gasket. I made a mistake however, and used the old head bolts as new ones were so expensive. Meanwhile, I have since bought several sets when they were available on RockAuto.com. They are no longer offered there as I just looked. With your set from ARP you should be even better off. The indication that I had a head gasket problem is that my Jeep started overheating. The odd thing is that my engine would be hot but my radiator would be cold. I realized that the combustion gases were accumulating in the radiator and displacing the coolant. After struggling with this for a while, I finally figured out that if I took the rubber gasket off from the plunger portion of the radiator cap it resolved my problem. The removal would allow a very small continuous flow from the top of the radiator to the expansion tank effectively causing the accumulation in expansion tank which in turn purged the gases instead of the coolant as it had been doing. I believe that this trick would allow a significant amount of head gasket blowby before becoming an issue. I would remove the gasket even if you don't suspect an issue because the problem has been so prevalent with these engines and I would prefer the vehicle would never overheat.
Another challenge I had with my diesel is the vacuum pump. And again, my situation was not by any means isolated. The diaphragm would eventually get a small hole in it and the pump would start drawing the oil out of the engine and putting it on the ground. They later improved the design. I heard someone discuss a mod that was popular in Europe to resolve this on the earlier vehicles like ours. I don't remember any details. I ran out of oil twice due to this. If your oil pressure gage says you are running half pressure you probably have little oil in the sump. Heed the warning! However, I removed a bearing cap to inspect a bearing and it was beautiful, so no harm.
I have enjoyed my Jeep very much. I got about 30 mpg with it. The performance reminds me more of a small gasoline engine than a diesel. It is not what I would call a torque monster and is willing to rev up a little bit.
I and others have put worthwhile lessons learned on this site including technical problems and where to buy parts. It would be worthwhile to do some reading if you have one of these vehicles.
Old August 23rd, 2014, 10:04
Re: 1986 diesel XJ
I completely forgot about this post till now, so sorry for the delayed reply. I have done a lot of reading on this engine and am very familiar with diesel engines in general. I was originally gonna just get this motor fixed and running, but after seeing all the leaks, and soot in the cooling system, I decided to pull it out and rebuild it. I've collected all the parts and gaskets and just waiting on getting the time to do it. My head gasket solution is gonna be to get the top of the sleeves machined down flat with the deck. Then get the head the o-ring treatment. The o ringing is where a groove is machined in the head that is right where the compression ring is on the head gasket. Then a .020" diameter stainless steel wire is pressed into the groove. when the head is torqued down the wire clamps down on the compression ring super tight, holding tight enough to hold back 70psi of boost on hot rodded diesel trucks.
I think getting all the sleeves machined perfectly flat will be a big help, Im sure there would be a few thou difference between them stock. I think starting with a flat, solid foundation and clamping the head gasket good in the right spot, with best in the world fasteners, I can say bye bye to head gasket problems. I'm gonna follow the other fellows advice and install an electric fan to keep air moving when its shut off, sounds like a good idea. Also did you follow the 4 step head bolt tightening sequence? ARP are not torque to yield like the factory bolts, so I was just gonna torque em down to 90 ft/lbs and see if there is any head distortion.
Thank you for the very informative reply, there aren't many of these out there, but the people who have them seem to be more than willing to help others.
1986 Turbo Diesel XJ Gearing? jfiscus OEM Tech Discussion 17 April 27th, 2008 13:41
1986 Jeep Cherokee XJ Turbo Diesel - $1000 OBO jfiscus For Sale: Private Party Only. XJ ITEMS ONLY 6 April 20th, 2007 05:47
1986 Cherokee Turbo Diesel deisenba OEM Tech Discussion 17 December 15th, 2005 14:27
1986 diesel Jeep Cherokee fuel system adrien OEM Tech Discussion 5 December 9th, 2005 10:05
