Old December 4th, 2017, 18:11
SeansBlueXJ's Avatar
SeansBlueXJ SeansBlueXJ is offline
replaced CPS now I have coil pack codes?
I was out in my 2000 4.0 running errands I had a moment when it cranked and didn't start, then tried again started up. This happened again and then it threw the code P1391. Then after my last time starting it I had several times it stalled out etc. Finally got it running consistent and then headed home. Got home OK but then was having several issues starting. I changed both the Crank and Cam position sensors, left the battery disconnected etc. The jeep still has the same issues starting, I need to go through several cycles of cranking it. Well when it starts, it will idle fine, but any increase on the throttle, or any attempt to move throws it into rough idle, and most likely a stall.
The codes I am pulling now however are different. p0351/0352/0353 Ignition Coil A/B/C primary/secondary circuit. So any thoughts? I do not just want to go chasing gremlins and throwing money I don't have at this time. This is still my daily and I can't afford to have it down long. Please help!
Old December 4th, 2017, 18:27
RCP Phx RCP Phx is offline
Re: replaced CPS now I have coil pack codes?
I think those codes are telling you where you should start. Something's not right with the new parts/installation!
Old December 4th, 2017, 20:03
Huh?
Old December 5th, 2017, 04:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Did you buy genuine Jeep sensors ?
I suggest you problem solve for the P1391.
P1391 - Intermittent Loss of CMP or CKP Signal. Loss of the Cam Position Sensor or Crank Position sensor signal has occurred.
P1391 – Possible symptoms:
(1) random misfire/stumble/stalling, often over bumps or right turns and when going into reverse.
(2) shorted out the Fuel pump/ECU power wire.
Possible causes
- Faulty CamshaftPosition (CMP) Sensor
- Camshaft Position (CMP) Sensor harness is open or shorted
- Camshaft Position (CMP) Sensor circuit poor electrical connection.
Symptoms:
CMP SENSOR OUT OF SYNC
-DAMAGED TONE WHEEL/FLEX PLATE (CRANKSHAFT)
-DAMAGED TONE WHEEL/PULSE RING (CAMSHAFT)
-IRREGULAR LAB SCOPE PATTERN OF CMP SIGNAL
INTERMITTENT CKP SIGNAL LOSS WHEN WIRING IS WIGGLED
-IRREGULAR LAB SCOPE PATTERN OF CKP SIGNAL
-WIRING HARNESS INTERMITTENT
INTERMITTENT CMP SIGNAL LOSS WHEN WIRING IS WIGGLED
-SENSOR CONNECTOR/WIRING
-CAMSHAFT POSITION SENSOR
-CKP SENSOR CONNECTOR/WIRING
-CRANKSHAFT POSITION SENSOR
Often replacing the sensor fixes this code, but not necessarily. Therefore it's important to check the following:
• Check that the wiring isn't routed too close to to sharp metal edges, or to hot exhaust parts.
• Visually inspect the wiring at the sensor for any burn marks, discoloration indicative of melting or chafing of insulation
• Visually inspect the cam sensor for damage
• Visually inspect the reluctor wheel inside the alternator. Make sure the magnet is firmly attached.
• If all checks out okay, then replace the sensor.
If you buy any OBD-II engine sensors, make sure to buy genuine Jeep sensors.
Potential Fixes:
Fix #1:
Inspect your wire harnesses for damaged wires, chafed insulation, or failed wire splices. Use a volts/ohms multi-meter to check the resistance of the ground wire circuits from each sensor. Replace corroded ground wires/connectors and clean ground wire connection points.
Fix #2:
Timing may off. Re-index the distributor/cam sensor per the FSM instructions, or replace faulty distributor/cam sensor pickup module.
Google Scan Tools, O-Scopes and Toothpicks, and read the article.
A mis-indexed distributor/cam sensor may exhibit surging, light bucking or intermittent engine misfiring. This will most likely occur when the vehicle is at operating temperature and under a light load at approximately 2,000 rpm. The proper indexing procedure must be used as outlined in the Jeep Service Manual.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 5th, 2017, 07:29
blakews2217 blakews2217 is offline
Same thing happened to mine when the CMP sensor had failed. Be sure you indexed it correctly.
If you look on the synchronizer body there’s a small pinhole in it and the rotor inside it.
Loosen the bolt on the engine block so you can turn the entire synchronizer body
Turn it so you can line the holes up ( may have to bump the starter so you can get it close)
Put the paper clip through the holes and tighten the bolt.
Install sensor cap and plug it in. Then try to start it.
Old December 5th, 2017, 11:43
Originally Posted by Tim_MN View Post
Did you buy genuine Jeep sensors ? .
I didn't, but I have a crank sensor I just ordered from Jeep today. Starting there.
Old December 11th, 2017, 10:52
Put in Mopar sensors. will not start. At least with the Auto store stuff I could get it to run, it would idle fine but die out with any throttle... Related? Maybe not. But still not starting. Thoughts?
Old December 11th, 2017, 11:11
Tim_MN's Avatar
Replaced ignition coil and on to exhaust SFXJ125 Colorado Chapter 32 April 28th, 2017 09:36
Coil pack, 00/01 4.0 Fore Wheeler MWC For Sale/Wanted Forum 1 December 12th, 2012 09:12
Wanted: Coil pack for 4.0 coil on plug Brandoson Arizona For Sale/Wanted 0 October 17th, 2012 21:45
Where can I buy a Coil Pack? klennop OEM Tech Discussion 13 May 4th, 2007 08:42
No spark, replaced CPS, ECU, ASD relay... nothing getting to the coil RubiconXJ90 OEM Tech Discussion 12 June 5th, 2006 21:51
