Old December 3rd, 2017, 22:46
bradleyheathhays bradleyheathhays is offline
How to bend the end of your tail pipe
Can't believe it but the new shackles are running into the end of my exhaust so the stock XJ is having it's first clearance issue.
My best idea is to protect the tank with a welding blanket and heat red hot where I want the bend and then stick a 2ft pry bar in there and see if I can get it to move. I don't have a serious torch so the best heat I'd have available is just propane or this new MAPP gas, which are about the same thing. I'm not sure if plain propane would get hot enough. Can this be done with anything short of an acetylene torch?
And how close is too close routing it by the gas tank? If I don't bend it down some it'll end up being a bout 2" away.
Old December 3rd, 2017, 23:25
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: How to bend the end of your tail pipe
Cut tail pipe. Put on bent piece of pipe.
Old December 4th, 2017, 06:01
lawagoneer lawagoneer is offline
Muffler shop make short work on it and shouldn't cost much.
Old December 4th, 2017, 16:38
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Driving off-road usually does a number on the end of the tail pipe.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old December 4th, 2017, 20:30
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
That's the easiest solution I came up with for myou clearance issue.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old December 14th, 2017, 10:01
jeeperguy21's Avatar
jeeperguy21 jeeperguy21 is offline
Back in the day, I cut off the pipe so the exhaust ended before the shackle. Later on, when I replaced my muffler, the shop put in new piping and installed it to easily go around the shackle.
Old December 15th, 2017, 08:48
burntkat burntkat is offline
NAXJA Member #1145
This is the only way to do it on the vehicle. Trying to heat it hot enough to bend, right by the tank, is asking for a disaster.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old December 15th, 2017, 08:49
NAXJA Member #1145
I did the same thing. Unfortunately, I also found that the hot exhaust gasses made short work of the bushing in said shackle.
Old December 15th, 2017, 15:32
Greenz's Avatar
Greenz Greenz is online now
After lifting and hearing the clunks, I knew it was rubbing. Seen where mine was rubbing. Smacked it a couple of times with a ball peen hammer. Lost 75.6 HP denting the exhaust. Won't do that again.
JK... Didn't notice anything except quietness. It will be fine until the exhaust needs to be replaced.
Old December 15th, 2017, 20:42
Dragonlich1961 Dragonlich1961 is offline
I installed a gibson cat back in my 94 as well as a zj tank skid , trailer hitch( which is stated in gibsons instructions that it does not fit with) and HD no lift shackle reloaction brackets and RC extended shackles. found out the 2.5 inch pipe ,as well has everything else was a tight fit. ended up taking the pipe and putting it in a press to flated the pipe and turn it into more of an oval shape where the shackle to leaf bolt is, also had to put the bolt in so that the nut is out. The pipe was rattling, so its bolted to the tank skid with a exhuast clamp. its a tight fit and the shackle hits the pipe while articualting but it clears 80% of the time. Only time will tell if the heat does damage to the bushing.
MJ tail lights, down pipe chedisme Winterfest 2014 Swap Meet 4 March 6th, 2014 10:08
Adding a slight bend to an exhaust pipe travisk OEM Tech Discussion 29 January 28th, 2014 14:05
bent my tail pipe AaronJXJ OEM Tech Discussion 7 February 11th, 2008 19:22
trimming my tail pipe Blkxjkrawler Modified Tech Discussion 28 August 29th, 2006 07:14
(tail) pipe dreams.. sidriptide Modified Tech Discussion 5 December 28th, 2003 13:08
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
