Old December 3rd, 2017, 15:55
Baddad Baddad is offline
Distributor install ‘91+ HO
Baddad's AvatarBaddad , 11-29-2017 11:51 AM
Bottom line; TDC engine on #1 cylinder. Install distributor so rotor just PAST #1 terminal on the distributor cap!
My sob story; My sons ‘96 distributor bushing was so bad it broke his rotor! The shaft wiggled 3/8” side to side! Can’t believe it ran for that long with a bad bearing and no noise 😮. Anyway, got a new distributor from Oriellys and tried stabbing it into the same alignment as the old one but it was kinda guess work since the shaft was so loose. The engine wouldn’t fire so we TDC #1, lined up rotor with #1 post, installed it and after a bit of cranking she fired up and idled fine. Rolled it over to shop to button up the wording. Victory! (Not!) went to restart it and all it would do is crank! Argh! Wiring good, firing order good, coil checked out (replaced anyway), cps tested good, refreshed grounds, checked fuses and relays, cleaned electrical plugs, fuel pressure good, injectors injecting, finally exchanged distributor, NOTHING WORKED! Finally my buddy, suprmn, found a post referring to the rotor pointing just PAST the #1 terminal, so I figured, wtf, give it a try. Lined up TDC AGAIN, then installed distributor with rotor pointing as described, it fired up and runs great!!!! WHY IS THIS NOT IN ANY OF THE DIRECTIONS, servicemanuels, etc! And THATS what that little plastic pin is for in the new distributor, an alignment pin! I’ve done literally hundreds of distributor installs and this is the first application I’ve seen this! Hope this post saves someone 2 days of headaches!
Old December 3rd, 2017, 18:44
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: Distributor install ‘91+ HO
It's a well kept jeeper secret how to index the dizzy. Be glad it was not an 87-90 Renix Cherokee, LOLOLOL
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old December 4th, 2017, 07:07
cruiser54's Avatar
cruiser54 cruiser54 is offline
Here ya go:
http://www.angelfire.com/my/fan/dist_index.html
Old December 9th, 2017, 09:25
I guess part of my problem was I was searching for the resulting symptoms believing I had put the distributor in correctly. Oh well, live and learn!
Old December 9th, 2017, 10:52
cruiser54's Avatar
Happens all the time. LOL.
Never happened to me though. Ever................
renix distributor install walkthrough downhillracer OEM Tech Discussion 8 August 27th, 2011 07:41
Distributor install ParadiseXJ OEM Tech Discussion 4 February 21st, 2011 12:25
Symptoms of getting the Distributor off a tooth on install? Redsnake OEM Tech Discussion 3 April 4th, 2008 13:24
Distributor Install rws OEM Tech Discussion 9 June 14th, 2005 08:04
Local shops: gear/locker install and tranny install Big Red Sierra Chapter 4 August 2nd, 2004 15:37
