Old December 1st, 2017, 21:13
bradleyheathhays bradleyheathhays is offline
Fumes and weight management
First is putting the 96 XJ up on stands. Considering the weight of the engine and that there's no real frame under there, would it be risking bending the body to put the front of the truck up on stands? Doing a lot of front end work right now and I have both front wheels off and two stands positioned supporting the 'frame' rails right where the front doors meet the quarter panels. Have some 2x4s running length wise b/t the stands and rails to spread out the pressure.
And second is a concern I have about the company vehicles I'm asked to drive at work. We have a set of mechanics now that don't fix any problems that deal with fumes getting into the vehicles, and will tell you they're harmless. So recently I'm in discussions with higher ups about how to measure the air quality in the vehicles. The two situations I see most often that allow fumes in are leaky head gaskets dripping oil onto the exhaust manifold, and leaky exhaust manifolds.
So I'm wondering what kind of device do I need to get my hands on to measure these pollutants? Less expensive is good as I'm having to do this myself. Would be ideal if I could maybe just rent something. The device would need to measure carbon monoxide, but hopefully unburned hydrocarbons and nitrogen oxides as well.
Old December 1st, 2017, 22:36
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Re: Fumes and weight management
They sell household CO monitors you could throw in the cab?
And your method with the jackstands is fine. It won't fold like a taco, unless you take the doors off of course. Then it'll implode
Old December 2nd, 2017, 07:07
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I will second the CO detector. Pick one up at the local Home Depot/Lowes/Ace...
If the CO detector takes issue with the fumes then you have something objective to complain about. If management can't grasp that then I expect someone at OSHA could explain it to them in terms they will understand.
Old December 2nd, 2017, 11:22
trippled trippled is offline
And any exhaust leak forward or directly underneath the cab are a DOT failure.if they are bad enough to smell they're bad enough to fail.
Poor gas mileage, exhaust fumes burns eyes. MaxxXJ OEM Tech Discussion 24 January 2nd, 2013 12:35
Herculiner fumes/odor in XJ stephenspann27 Paint and Bodywork forum 15 February 25th, 2010 10:44
TCM GLX's XJ Under New Management Sig Ep Mock SoCal Chapter 25 December 30th, 2008 09:21
Fumes in the garage kdailey4315 Modified Tech Discussion 4 August 5th, 2008 14:47
Sprung weight vs Unsprung weight.... Ghost Advanced Fabrication and Engineering 14 October 24th, 2006 13:23
