Old December 1st, 2017, 17:41
wvredxj's Avatar
wvredxj wvredxj is offline
Vanilla Latte build
This is my third xj build. First one was a complete bolt on credit card jeep way back in 2006 with a Clayton 8" longarm and 35's. Jeep was fun, and i became hooked:
In 2008-2009 i built my next one. One tons, atlas, 14" fox coilovers, stretched, caged, full hydro steering, originally on 39" red labels:
then came the 42" sxII's, then 44" boggers, then cut boggers, then cammed 5.3l with bolt on's and a 4l60e:
and now Vanilla Latte. This jeep is what i met my wife in 12 years ago. This was hers in college, and then i drove it for a while. It was a pristine stone white classic. During the recent years as a work vehicle it did have a few bruises added to it, and at 180,xxxk miles it needed a refresh. So i built some bumpers, threw a bb lift and some 31's on it and monstalined it sands panties (vanilla latte as i call it). Then we built some sides out of 1/8" metal and i bent some tube flairs. It was driven for a while and parked. After putting that much time in the body, i knew it needed something, just didnt have a plan till now.
Since this jeep has been around this family for so long, i wanted a built that would progress and not necessarily a rock crawler. Something i can mildly wheel, still drive on the road, hunt out of, or go camping. Also it needs to haul the kiddo's and the wifey. So here we go:
Parts:
OME front Coil's (dpg 5")
OME rear leafs (dpg 5")
OME shocks
Crown Brake lines
Rubicon hack n tap
ford explorer 8.8
barnes 4wd u bolts, spring plates and all the tube adapters
FK JMX 1.25 heims
4:88 gears
Front Grizzly locker for dana 30
WJ knuckle conversion
Liquid iron slider boxes
ruff stuff one ton steering
35x12.5x15 mickey thompson mtz's
I trimmed it pretty hard when i built the tube flares, this is essentially no lift and the 35's:
Old December 1st, 2017, 19:37
wvredxj's Avatar
Re: Vanilla Latte build
i have had to move my photos from photobucket to imgur, and am still getting used to the new hosting site, here are some updated photos:
Old December 1st, 2017, 20:33
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Nice work.
I really like the bends in that T-case skid, but how does it unbolt from the frame side? More pics?
Old December 1st, 2017, 22:01
Heavyopp Heavyopp is offline
Those rear leaf spring slider boxes -- Better than shackles? What did you chose them? Not criticizing, just trying to learn something new
How about your upper arms -- What did you do for them?
Last picture posted. Right side, top of Long arm mount where it looks welded to the frame stiffener -- Is that a cracked weld?
I'm new to the XJ, trying to learn what I can from some of you "seasoned" guys
Old December 2nd, 2017, 06:09
ehall's Avatar
ehall ehall is offline
looks good
my '91 beater rebuild
Old December 2nd, 2017, 11:53
wvredxj's Avatar
got some more done:
wj knuckle swap pretty much done.
Old December 2nd, 2017, 11:56
wvredxj's Avatar
dont know about the sliders yet, but they are beaf. I think i will like them.
Here is the the upper, driver side three link, all links are made out of 2" .25" wall square with barnes inserts, FK JMX 1.25 heims, and stainless high misalignment spacers. 5/8" bolts.
Here is the crossmember before skids and paint:
Old December 2nd, 2017, 13:09
trippled trippled is offline
Nice job so far. Looks like a lot of work went into the cross member.
Old December 2nd, 2017, 15:10
You guys are definitely inspiring me to build my own crossmember and 4 linked front end
Looks like you fabricate like I do -- no brake to bend plate -- everything made from flat plate and welded together -- I've been building this way for years, actually been thinking about building the swag off-road 40" finger brake as my xmas present to myself this year
Old December 3rd, 2017, 12:41
twinhauler's Avatar
twinhauler twinhauler is offline
Really nice work!
Old December 3rd, 2017, 15:24
wvredxj's Avatar
I have a 30" brake in my 50 ton press. Here is the trackbar axle mount i bent. Every bracket on this i built, only thing bought was the clayton front axle bridge and the rear leaf spring mounts/spring plates.
Old December 3rd, 2017, 18:38
I see the brake on the press in the picture of the rock sliders,fender,tire
What kind of preformance do you get from the 50 ton 30" combo?
Old December 3rd, 2017, 18:48
Kittrell's Avatar
Kittrell Kittrell is offline
Does your tie rod clear that TB bracket at full lock?
Old December 3rd, 2017, 19:38
wvredxj's Avatar
yes i will get a pic, thats why i bent the bracket. my bracket is only 1/4" wider than the stock track bar mount, and i drilled holes to plug weld onto it. Most of these brackets will get filler plates put in as well. Once the axle comes back out for regear/paint i will finish weld everything and add my gussets.
The brake works well, it has bent everything i have asked it too.
Old December 12th, 2017, 08:50
831_xj's Avatar
831_xj 831_xj is offline
Nice work, dog the xmember
I know a little bit about nothing..
Daily MJ
yewwy crawler
Vanilla Gorrilla blog GordoSmasho Sierra Chapter 454 December 16th, 2017 18:44
My buggy build....... well, continuation of a build. YELLAHEEP Colorado Chapter 39 November 18th, 2016 00:49
build a dream xj, what would you build poomero NorthWest Chapter 13 February 6th, 2016 07:44
Vanilla Ice and MC Hammer .. together at last. urban yan Non-Tech / Off Topic 4 February 13th, 2009 13:43
Vanilla Pudding Robbery bjoehandley Non-Tech / Off Topic 3 June 5th, 2007 21:49
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
