Old December 1st, 2017, 17:13
Slimer Slimer is offline
Blew the Reservoir on NEW Power Steering Pump!
UNCLE!!
What did I do?? I originally broke the little plastic nipple on the back of my power steering pump reservoir when I changed the radiator. Instead of replacing the pump I just replaced the reservoir.
Of course it leaked and kept leaking no matter how I tried to seal it up. I took the pump off the reservoir off three times.
So I broke down and went to NAPA for a new pump with reservoir already installed. I put it on, flushed the system and first blew the low pressure return line. I replaced it and then blew a hole out the side of the reservoir.
What did I forget to do or did I get a bad pump? Any suggestions?
Here is how I bled the system.
Tighten the fittings
Wheels off the ground
Engine running
Turn the steering wheel from stop to stop (gently at the stops) 20 times
Engine off
Look into the reservoir for bubbles
Let the fluid settle down until there is no bubbles
Repeat the above
Wheels down
Turn the steering wheel stop to stop a few times
Check the fluid for excessive bubbles
Old December 1st, 2017, 17:31
old_man's Avatar
old_man old_man is offline
Re: Blew the Reservoir on NEW Power Steering Pump!
Logic would dictate that pretty much the only way to blow out the reservoir is to build pressure in the reservoir. The cap should have a vent in it to prevent pressure buildup. Sounds like you have a bad cap.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old December 1st, 2017, 20:26
Turned out to be a bad pump. I took the reservoir off and hooked to my air compressor electric motor and ran hydraulic fluid through it. The low pressure side or the return side had over 250 psi while the high pressure side only had 36 psi. Maybe they rebuilt it backwards, I don't know. I exchanged it and the new works fine. Strange.
Old December 2nd, 2017, 09:23
trippled trippled is offline
Sounds like the average reman! Glad you got it fixed
Old December 2nd, 2017, 23:08
Vgonman Vgonman is offline
I had a similar issue to your original problem. I also broke the input nipple off the reservoir and got a non-Mopar replacement reservoir. It leaked like a sieve where it connects to the pump. Turns out the o-ring that was supposed to seal it... wasn't. I ended up getting a batch of o-rings that ended up doing the job just fine.
FYI, this is what I ended up getting... M3x14 Viton O-Ring, 75A Shore Durometer, Round, Black, 14 mm ID, 20 mm OD, 3 mm Width.
If you want, I can send you one (I had to get a pack of 10). PM me if you want one. That way you have a spare reservoir.
Old December 3rd, 2017, 10:25
Hypoid's Avatar
Hypoid Hypoid is offline
Where did you find these, part number?
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old December 4th, 2017, 01:23
Here's the link to what I got...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
But, like I told Slimer, I had to buy a 10 pack to get the 1 I needed. I still have at least 8 left. If you'd like one too, shoot me a PM with your address and I'll send one your way.
Old December 4th, 2017, 08:57
Vgonman,
Thank you for the kind offer. It stopped leaking when I replaced the entire pump.
Ryan
Remote steering pump fluid reservoir for stock pump mountainjazz Modified Tech Discussion 17 March 27th, 2012 13:43
Blew a hole in my power steering gear box cap jwtrapper Modified Tech Discussion 8 October 30th, 2010 20:17
Power Steering Pump Reservoir Fix? spudly OEM Tech Discussion 6 April 22nd, 2007 18:37
power steering pump reservoir ccflexj OEM Tech Discussion 5 December 30th, 2006 02:06
Power steering pump reservoir CGEMC OEM Tech Discussion 3 March 11th, 2006 15:02
