Replacement Bushings
Slimer
Tempe, AZ
My XJ has handling issues that I am trying to remedy. It has a BDS long-arm kit on the front end and several of the bushings in the arms look worn. What bushings do I use? Any suggestions? Rubber? Poly? Urethane? or even orbit-eyes?
I am replacing all the bushings in the upper and lower arms and the trac-bar.
Also, the orientation of the upper control arm bracket (passenger side) on my Dynatrac axles appears to be canted with more than an angle than required. Do I have to cut this bracket off and reweld on a new one or should I try to find an arm end with a similar bend or angle at the end?
Thanks!
I try to do rubber as much as possible, but I would think that might be limited to whatever BDS used originally! There are a lot of retro-fit joints out there now.
