Old November 28th, 2017, 20:16
bradleyheathhays bradleyheathhays is offline
Need advice for pressing in axle side UCA bushing for XJ
Been replacing all 4 control arms on the 96 XJ and to my amazement everything has gone well so far. Replaced the bottom 2 ok, and the driver side upper went in w/o too much trouble...so but now I'm into the upper arm on the passenger side. Pressing the bushing in on the driver side went ok as it goes into a cast iron part of the axle, but the pass side bushing mount isn't nearly as solid and I'm wondering how this one's gonna go. Basically I'm looking at pressing bushing through two circles of metal with not much support metal in between. And as much force as it's gonna take I would think those two metal surfaces would end up collapsing toward each other as the C-clamp + bushing setup is tightened.
If I had the right size pipe and a MIG I'd insert a small section of pipe between the circles to make sure I didn't fold things up.
I've rented a big C-clamp ball joint 'maintenance kit' w/ a lot of different sized cups from a car store for the job. Any tips/tricks/advice on how to get this particular side done?
Old November 28th, 2017, 21:27
Dragonslayer Dragonslayer is offline
Re: Need advice for pressing in axle side UCA bushing for XJ
I made a spacer from 2" i.d. PVC plumbing pipe (Home Depot, etc.).
A hair less than 1" in length ... then cut a section off along its side so that the
whole thing looks (sort of) like the letter "Ω". The cut away section allows you
to remove the spacer after the bushing is in place.
Shove the thing in-between the bushing mount uprights and slowing press the
bushing in. Remove when done.
Cheap. Doesn't scratch the paint. Works like a charm.
Old November 28th, 2017, 22:53
md21722 md21722 is offline
Right, you pack it with metal to keep it from collapsing.
Old November 29th, 2017, 10:03
Sounds good.. just anything shoved in there while the compression is going on will do. Doesn't need to be something as permanent as my idea.
I ended up having to cut the bolt to the same pass UCA axle side bushing, and I'm concerned about clearance issues replacing it with a regular six-sided bolt. Did Jeep make the OEM bolt with that funny type of flag head because of clearance issues say when if the arm were to get pushed way up during heavy suspension compression?
Old November 29th, 2017, 10:44
RCP Phx RCP Phx is offline
Hex heads work fine, the flag bolts were for easy factory assembly.
Old November 29th, 2017, 13:45
Some johnny engineer came up with that flag bolt. It's a pain in the ass. A regular hex bolt will work fine as RCP Phx says. Just take the bolt down to the local Ace Hardware and get another one.
Axle side UCA bushing replacement XJ_99 Colorado Chapter 6 March 6th, 2014 07:49
Opinion on Upper control arm axle side bushing adrenalinepirate Colorado Chapter 3 March 15th, 2013 15:12
Axle-side upper control arm bushing replacement anthrax323 OEM Tech Discussion 13 September 4th, 2010 22:04
replacing axle side upper control arm bushing? bmyohn OEM Tech Discussion 2 September 30th, 2009 20:40
Control arm bushing loose - axle side 00XJFAN Modified Tech Discussion 5 October 21st, 2008 20:49
