Old November 28th, 2017, 11:14
BALTANAKT BALTANAKT is online now
Will '93 Wrangler 4.0 swap straight into '91 XJ?
Just checking before I pull the trigger on a motor.
Thanks!
Old November 28th, 2017, 14:26
bigdaddyjlove bigdaddyjlove is offline
Re: Will '93 Wrangler 4.0 swap straight into '91 XJ?
Are you just swapping the long block? If so, yes it will fit fine. If you are swapping everything, then I think it should work, but I can't be certain.
Old November 28th, 2017, 18:56
Yes, just the block, thanks!
Also wondering:
- I've aways had my heads decked when replacing head gasket. It seems this is not common procedure with the 4.0?
- Is it easiest to remove the whole package (motor, trans, t-case) as a whole, or just the motor alone? Will be doing this alone.
Old November 29th, 2017, 04:42
cruiser54's Avatar
cruiser54 cruiser54 is offline
Just the engine.
Only radiator needs to be removed.
When unbolting the engine mounts, do it at the frame. Leave the crossbolts in.
Old November 29th, 2017, 07:48
ehall's Avatar
ehall ehall is offline
The engine is the same. Couple of electronic pieces are probably different (injector or a sensor or something). Look up the interchange on rockauto or just move your parts over.
my '91 beater rebuild
Old November 29th, 2017, 08:08
Also wondering:
I've done it both ways. If you are by yourself, I would recommend just pulling the motor. The 4.0/AW4/Tcase is a LONG assembly. It gets difficult to pick it up far enough back to not drop the Tcase on the ground.
Old November 30th, 2017, 08:00
Thanks fellas.
Hoping for good December weather.
97XJ I6 Swap into 98 Wrangler 99SJ_Ex Tow Rigs and Trailers 2 February 9th, 2012 08:18
2.5lt to 4.0 swap wrangler jaymels93 Tow Rigs and Trailers 2 December 11th, 2010 12:17
Straight 5 Engine Swap? xj92 Modified Tech Discussion 16 February 7th, 2010 21:01
wrangler tj/yj steering box swap to xj hidesintrees Modified Tech Discussion 6 March 14th, 2008 13:00
XJ ->Wrangler T-case swap (Help!!!) footdale Tow Rigs and Trailers 4 January 31st, 2005 17:56
