Old November 26th, 2017, 14:47
smallredxj smallredxj is offline
Hard start caused by coolant temp sensor?
Hey guys. Earlier today my Jeep started having rough starts. It will crank for about 10 seconds and then "sputter" to life. It idles rough for about 5 seconds and then it's fine. I can hear the fuel pump prime so I'm guessing it's not that- although I have not tested the check valve/ fuel pressure yet. I also know a dirty IAC sensor can cause this- but mine looked okay after cleaning. My main question is could this be caused by a bad coolant temp sensor? Mine went bad about a week ago and the Jeep has been starting fine until now. If it's not any of these things- what else could it possibly be? Thanks for the help.
Old November 26th, 2017, 16:22
old_man's Avatar
old_man old_man is offline
Re: Hard start caused by coolant temp sensor?
In order to help you need to provide more info. What year model, transmission, and engine is it? When the problem happens, is the engine warm, has it been started recently or is it cold?
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old November 26th, 2017, 17:24
Fidget360's Avatar
Fidget360 Fidget360 is offline
I would say that it certainly could cause that. I had a car a while back that had the same condition and it was all due to the coolant temp sensor. If the ecm doesn't see the coolant temp, then it will assume the worst and go as rich as possible to make sure that it has enough fuel to start. I'd bet that it's also killing your gas mileage.
91 XJ Craigslist special: $350 for the jeep. 250K+ and running strong.
Idiots affect the lives of many. There is still no known cure for stupidity, but we can raise awareness ......
Old November 26th, 2017, 18:04
99 4.0 auto
140,000 miles
Old November 26th, 2017, 18:18
That's what I was thinking- the temp sensors failure put it in limp mode.
Old November 26th, 2017, 20:15
Well I hung it up for tonight but after testing stuff a little more I think I may not be getting spark- or it's at least intermittent. The truck reeks of gas so I know I'm getting fuel- not to mention I tested the pressure, however it's still a b***h to start. I can crank for 10-12 seconds and get nothing. I know for sure I'm changing coolant temp sensors, and my IAC because it was dirty as crap but what else should I be looking at? Maybe my CPS? I'll test for spark tomorrow I just ended up running out of daylight. I'm pretty stumped so help would be greatly appreciated.
Old November 26th, 2017, 22:18
Ralph77 Ralph77 is online now
I had a buddy with a '96. Was running like crap so he tuned it up. New wires, plugs, cap, rotor, and fuel filter. No change. Drove him nuts until he figured out it was the temp sensor in the thermostat housing.
Old November 27th, 2017, 05:11
cruiser54's Avatar
cruiser54 cruiser54 is offline
Ya know, if the vacuum line to the MAP sensor has a split, cut, or leak, the thing will run pig rich and act just like you're describing..........
Coolant Temp Sensor heyhar OEM Tech Discussion 18 November 4th, 2011 23:24
Bad coolant temp sensor??? deskjockey OEM Tech Discussion 2 October 6th, 2007 19:11
Coolant Temp Sensor Blaine B. OEM Tech Discussion 14 April 22nd, 2007 19:32
Coolant Temp Sensor saint_raider OEM Tech Discussion 5 June 22nd, 2004 19:33
Coolant Temp. Sensor Xtreme XJ OEM Tech Discussion 8 June 30th, 2003 18:16
