Old November 25th, 2017, 11:37
stefanoquinto's Avatar
stefanoquinto stefanoquinto is offline
wj fron brake conversion
thanks to this forum I've easily do a rear disc brake conversion.
now I would like do a front brake and steering conversion, and I've some question about this upgrade:
I must put 16 inch wheels?
there are a thread step by step for this job.
excuse me for my english.
thanks before to all.
Steve
Old November 25th, 2017, 12:07
RCP Phx RCP Phx is offline
Re: wj fron brake conversion
This video covers most of it thoroughly. When I did mine I did not do anything with steering mods. I just needed the braking!
https://www.youtube.com/watch?v=SjpEc07AJxM
Old November 26th, 2017, 19:23
yossarian19's Avatar
yossarian19 yossarian19 is offline
You can fit "some" 15" steel wheels, but not all of them, and if you have aluminum wheels they have to be 16" or larger.
Use something like this to re-drill WJ brake rotors to 5x4.5
The WJ steering knuckle mounts the tie rod 3/4" lower than stock.
The 93-98 (ZJ) Grand Cherokee pitman arm also moves the steering 3/4" lower, so you can use it to compensate if you don't want to change your whole steering setup.
I had an XJ with ZJ rear discs and WJ fronts... I have never had a car that stopped so well, before or since. I miss it!
Old November 27th, 2017, 00:00
Thanks for reply. I've asked for wheel diameter because in italy isn't legal change the wheel diameter (stupid law).
I can only use 31-10.50 x 15 or 33-12.50 x 15....
Old November 27th, 2017, 00:19
Tin Man Tin Man is offline
I was able to put 15" Method Bead Locks on my conversion,I had to sand the calipers a little but that's it.
Old November 27th, 2017, 05:00
whitexj98 whitexj98 is online now
Running 15x8, 3.75 BS steel wheels clear my WJ setup.
Here is pretty much everything I used (far left column).
https://docs.google.com/spreadsheets...it?usp=sharing
Old November 27th, 2017, 08:05
chickenbot chickenbot is offline
What are the other 2 columns?
Old November 27th, 2017, 08:22
Just other build combos/ prices I thought about.
Old December 2nd, 2017, 00:05
I suppose that will be more easier do just brakes upgrade...
14 bolt disc brake conversion brake lines (or anyone using k20 front calipers) blondejoncherokee Sierra Chapter For Sale 0 August 19th, 2014 11:56
disc brake fron dana 30 techshooter02 OEM Tech Discussion 5 October 14th, 2008 19:42
Rear brake conversion to disk brake XJ97 Oseberg OEM Tech Discussion 3 February 3rd, 2008 15:25
Fron Brake Rotor Delima FitchVA OEM Tech Discussion 8 August 28th, 2007 05:42
D44 disk brake conversion: brake line questions Kejtar Modified Tech Discussion 2 December 17th, 2005 23:35
