Old November 23rd, 2017, 18:09
Quickbird144 Quickbird144 is offline
Whining sound but only when in 4wd?
Hey guys. Been using these forums for help for awhile and just now joined. Hoping maybe I could get some direction to go with a problem I'm having.
Have a '99, auto, 4wd swap from a '00. Np 231 case now with SYE.
At​​​ the time I was completely stock. No issues with anything, smooth swap. Since, I have a 4.5 LA full lift, and SYE.
Lately I've noticed while driving if I pop it in 4hi, on decel I have a gnarly roar/whine. If I'm on the accelerator, no problems, back off and I hear the whine. While on decel if I pop it back in 2hi, I hear the case switch and sound is gone. The sound also goes away with bumps on the road, suspension articulating I'm assuming.
I have a LP Dana 30. There is no play whatsoever from the front pinion, no side or in-out. However the pinion seal is leaking. I have just a hair in-out movement from the front yoke on the t-case. All fluids are new, probably within the last 1k miles. I've swapped driveshafts around with no change.
I'm thinking possibly front pinion bearing but don't want to get ahead of anything. Any help would be greatly appreciated.
Old November 23rd, 2017, 19:47
ehall's Avatar
ehall ehall is offline
Re: Whining sound but only when in 4wd?
Could be gear whine from the diff, but more likely to be gear whine in the transfer case
my '91 beater rebuild
Old November 30th, 2017, 20:08
BenWheelin BenWheelin is offline
I've always heard a little gear whine in low, but it was loudest with a failed input shaft bearing on the transfer case. In high, maybe it's chain slack rubbing the case?
I've had a front output seal squeak at low speeds before, they're easy to change.
Whining/whirring sound up front brielly OEM Tech Discussion 5 December 26th, 2015 11:03
Squealing / whining sound under XJ ngrubich OEM Tech Discussion 6 June 4th, 2015 18:31
Whining, but not whining sound? Cherokeekid88 OEM Tech Discussion 10 February 6th, 2012 13:22
loud whining sound... please HELP!! F1vestarGenera1 OEM Tech Discussion 11 January 16th, 2012 22:15
Strange whining sound from engine area mr_W OEM Tech Discussion 8 May 12th, 2006 13:22
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
