Old November 22nd, 2017, 19:24
PSoffe's Avatar
PSoffe PSoffe is offline
Question 96' Track bar mount loose
My son's 96 was making a lot of popping (sounded like someone hitting the frame with a small hammer). I traced it the trackbar mount at the frame. The track bar itself was not loose but the two lower bolts where loose enough to cause the mount to move left & right during any steering input.
The obvious was to tighten to spec which remedied the situation. Other than replacing the hardware all together, are there mods to strengthen this such aftermarket brace or perhaps lay a small weld bead approximately 1/2" long at each bolt location from bracket to frame rail?
Looking for ideas.
Old November 22nd, 2017, 21:52
RCP Phx RCP Phx is offline
Re: 96' Track bar mount loose
The RE set-up uses this............
Old November 23rd, 2017, 05:55
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
If the Jeep is stock, simply replacing the hardware and using thread lock on the new hardware is all that is necessary. Some people have welded the stock bracket to the frame. If you think something else needs to be installed, a double shear track bar with a new frame side mounting bracket is recommended. The RE brace is not necessary for a stock Cherokee or for light to moderate 4x4 use, and I doubt it will even fit a stock Cherokee.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old November 23rd, 2017, 08:06
trippled trippled is offline
I had that problem with mine and drilled the lower holes to take some larger bolts. I think I used 5/8 bolts. Never had a problem with it like that and works great for a stock Jeep. But if lifted I agree and upgraded bar and bracket is the way to go. I personally would not weld the stock bracket to the body.
Old November 23rd, 2017, 13:50
burntkat burntkat is offline
NAXJA Member #1145
Concur with Tim and the last gent. Additionally, I have heard folks run a front receiver to reinforce the front end.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
rubicon express upper control arms, and track bar plus a homebrew track bar mount sjstar Sierra Chapter For Sale 19 November 18th, 2011 17:15
Loose Track Bar Bronco OEM Tech Discussion 3 January 28th, 2006 08:52
loose t-case linkage, loose motor mount,or other? blue95xj OEM Tech Discussion 2 February 26th, 2005 22:18
JKS track bar and Rubi wheels coming loose... Jeep Cherokee Modified Tech Discussion 4 October 30th, 2004 06:44
Stock Track Bar Body Mount drilled to accept the RE1600 Track Bar xj92 For Sale: Private Party Only. XJ ITEMS ONLY 1 January 30th, 2004 11:08
