Old November 20th, 2017, 04:22
Joecat Joecat is offline
2.5 motor mounts
I have a 98 2.5 xj and the motor mounts are welded on. It looks factory,they look nothing like the ones on my. 99 4.0 , has anyone else run into this problem? I could not find any comments on this using the search on naxja.
Old November 21st, 2017, 19:17
lawsoncl lawsoncl is offline
Re: 2.5 motor mounts
You're talking about the mount with the rubber that bolts to the body, right? I'm pretty sure they're not welded from the factory. The pictures on RockAuto, they look pretty similar to the 99 4.0 ones. You need to undo the nut from underneath. Previous owner have an issue and just weld them on?
Old November 22nd, 2017, 04:09
No,they are welded on and it is a factory job, they donot look anything like the ones rockauto sells
to fir a 98 ,2.5,5 speed. The transmission mount is of the same design as the motor mounts and rock auto does not offer it either. Somebody else on naxja should on a 98/2.5/5 speed/xj with a similar setup and run into this,
Old November 22nd, 2017, 06:16
Jeep Driver Jeep Driver is offline
Others have run into this problem.
Post a pic.
No.
Post multiple pics.
Old November 22nd, 2017, 09:40
RCP Phx RCP Phx is online now
It may look like it was professionally welded, but the factory mounts bolt on!
Old November 22nd, 2017, 14:22
I do not want to start an argument but has anyone of you actually looked at a 98/2.5/4cyl/5 speed xj? This one uses a grand Cherokee style mount, and the transmission mount is the same design, rockauto does not list this mount for the 98, xj ,2.5,5 speed.
Old November 22nd, 2017, 15:08
Got any pictures?
Old November 22nd, 2017, 15:27
No.
Old November 22nd, 2017, 16:11
Both the 97 and 99 FSMs show the same drawing for the 2.5l engine.
Old November 22nd, 2017, 17:14
It is a 98, I can not explain it ,what is on the xj is nothing like these pictures,why would I make this up? But the welded motor mounts and the "unusual transmission mounts"look very factory. I am sorry but I don"t have a way to furnish pictures,just hoping some one dealt with this before.
Old November 22nd, 2017, 18:29
I'm just as curious as you, not sure why it doesn't look like what the FSM says it should.
JeepDriver said "Others have run into this problem.", maybe he can shed some light on this?
Old November 22nd, 2017, 19:36
You don't own a camera?
Is it round?
Old November 22nd, 2017, 19:53
Maybe Jeep Driver can help,as for the FSM the pictures they are for 97 and 99 models not the 98s. Don't understand Jeep Drivers last post.
Old November 22nd, 2017, 19:55
Last guy that had this problem found out that some of the export models used mounts similar or the same as the diesel mounts.
Is the mount more round in shape?
Old November 22nd, 2017, 20:11
I looked around...................
You need a camera and you need to take a pic of your mounts.
Don't know how anyone can help you otherwise.
ZJ 5.2 motor and iron man fab motor mounts - anyone on here want to do a v8 swap? blondejoncherokee Sierra Chapter For Sale 2 August 26th, 2016 10:34
New motor mounts azxj95 Modified Tech Discussion 23 December 3rd, 2009 00:56
Motor mounts tgregg OEM Tech Discussion 12 September 13th, 2008 20:52
Motor Mounts? MoparManiac Modified Tech Discussion 12 May 16th, 2007 13:26
Bad Motor Mounts? Bronco OEM Tech Discussion 13 October 20th, 2003 10:40
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
